need help about main and rod bearings for b18c1
Old Nov 6, 2006 | 07:49 PM
christion's Avatar
Default need help about main and rod bearings for b18c1
I was wondering if the ndc or clevite bearings are good to use. Does somebody out there had some problems with these bearings ( spun rod bearing or main bearings) I wanted to try those bearings, but need some advice. I'm going to use them in a b18c1 turbo with 20psi of boost.
Old Nov 6, 2006 | 08:25 PM
f20bej1's Avatar
Default Re: need help about main and rod bearings for b18c1 (christion)
i would get the oem bearings .if you look at your block on bottom i think oil pump side there are some numbers right them down and take them to honda they will give you the set that goes with your block.honda stamps the block with exactly what bearing honda oem
goat86
Apr 19, 2014 12:00 AM
SwagNationEK9
Nov 13, 2013 02:47 PM
MadVTI
Oct 4, 2009 05:47 PM
eg:R
Sep 21, 2006 05:33 PM
db2integra
Sep 20, 2004 08:25 PM
