How do I crank up the heat in my integra?
The heat switch on my climate control has broken and when I was trying to fix it, I noticed that the cable that should run to it was nowhere to be found. Is there a way I could turn the heat up until my new climate control unit shows up?
there is a little "****" (i guess this is the only way to describe it) under the glovebox where the cable "loops" over...if you find it, you will notice that it moves one way or the other, just experiment which way is hot and which way is cold and then you are in business
PM me if that didnt make sense though
edit: look towards the left side of under the glovebox...
