Whats It worth to you... May be selling...
Hey room wassup??? I own a 91 DA Integra and I was just wondering what you all thought and what something like this is worth... The motor just hit 8K this weekend from my 400 mile road trip and is daily driven on pump gas 15psi making 300+ whp and 215+ wtq... Thinking of selling it if the price is right....
Interior
-Kenwood Flip-Face Head Unit
-Sony Explode Front Speakers (6.5”)
-Sony Explode Rear Deck Speakers (6.5”)
-Audio-Bahn A-Series Amplifier
-Kicker Competition Solo-Baric 8” Sub with Kicker Matching Box
-Monster Cable 4-Way RCA’s
-Authentic JDM Broadway Mirror
-Crime-Stopper 2004 Alarm System
-Auto-Meter Phantom Series Electronic ½ Sweep Fuel Pressure Gauge
-Auto-Meter Phantom Series Electronic ½ Sweep Oil Pressure Gauge
-Auto-Meter Phantom Series Mechanic Full Sweep Boost Gauge
-Blitz FATT 3 Turbo Timer
-JDM GIGA Air Fresheners
Engine
-JDM B16A DOHC VTEC Engine
-JDM YS1 LSD Transmission
-Lexus GS400 COP Igniters
-Hondata Intake Manifold Gasket
-SIR Single Plenum Intake Manifold
-Competition Clutch Stage 4 Sprung Disk and Pressure Plate
-Integra GS-R Flywheel
-Ross Racing 9.0 Compression 81.5mm Bore Pistons
-Eagle Forged Connecting Rods
-Arizona Race and Machine Aluminum Block Guard
-GM 3 Bar Map Sensor
-ACL Racing Engine Bearings (Rods, Mains, Thrust)
-ARP Head Studs
-ARP 2000 Rod Bolts
-Polished Cast Aluminum FMIC w/2.5” Polished End Tanks
-Custom 6 Port Vacuum Manifold
-Custom Catch Can Setup
-Aeromotive Red Anodized Fuel Pressure Regulator 1:1
-Skunk 2 Intake and Exhaust Cam Gears (Red)
-Mildly Polished Throttle Body
-ERL Cast 4 Into1Polished Turbo Manifold
-Turbonetics T3 Super 60 Dual Ball Bearing Turbo
-2.5” Mild Steel 5 Bolt Down Pipe
-Bosch Manual Boost Controller
-Boomslang Fabrications OBD-0 to OBD-2A Conversion Harness
-Custom 2.5” Exhaust (No Cat… No Resonator…)
-Apex I N1 3” Turbo Muffler (Black Chrome)
-AEM EMS Engine Control Management 1050 Box
-Throttle Body Heater Bypass Modification
-Turbo-Smart External Dumping Waste-Gate (Turbonetics 9 PSI Spring)
-HKS SQV Blow Off Valve
-2.5” Turbo Charge Piping
-Precision 880cc Fuel Injectors (Seimens/Decka)
-Walbro 255lph High Pressure In-Tank Fuel Pump
-NGK Spark Plugs (.026 Gap)
-Energy Suspension Front Motor Mount Inserts
-Energy Suspension Drivers Side Motor Mount Inserts
-Energy Suspension Passenger Side Motor Mount Insert
Exterior
-Acura Integra “Fat 5” Aluminum Factory Wheels
-205/50/15 Dunlop SP 5000 Tires
-205/55/14 Nitto 555R Drag Radials
-Rota Slipstream 14” Knock Off Wheels
-KYB 4-Way Adjustable Shocks
-Eibach Springs
-Aftermarket 9006-HID Conversion (6000K/Blue)
-JDM PIAA H3 Yellow Fog Light Bulbs
-JDM Amber Bumper Corner and Turn Signal Lights
-Honda Emblems And Badges
-Power Slot Cross Drilled Rotors
-EBC Green Stuff Racing Brake Pads
-JDM Stainless Steel Adjustable Tag Bracket
-DC Sports Front Upper Strut Bar
-Freedom Designs Rear Upper Strut Bar
-Hella Air Horns
Imaculent Interior, Non-Smoker With all panels and working heat...
PS has a small spot of rust on the rear 1/4 panel on the drivers side about the size of a quarter...
Thanks everyone...
Interior
Engine
-ARP Head Studs
-ARP 2000 Rod Bolts
Exterior
-Eibach Springs
-Hella Air Horns
Thanks everyone...
i will trade u my whole car for some hella air horns...if u sell this car i will kill you bump this **** up for this tough guy ova hee, haters beware this thing is scary fast...seriously it is scary
M-doc yo!
Apr 9, 2005 08:11 PM
