****jdm b18c R swap 96****
basiclly i put the swap in, started the car up then sold the shell. so this swap has 0 U.S. miles on it. it is still in the car if you come by in the next couple of days before i remove the swap and deliver the shell. so that i can start it for you.
1996 spec jdm b18c R swap, s80 tranny w/lsd, obd2a p73 ecu, wiring harness
price break down and what comes with it:
swap from hmotorsonline: $3999.99
MSD Pro Billet distributor and coil/driver + wires. $400
ACT 6puck disc, act heavy duty pressure plate. $405
Hondata intake manifold gasket. $50
trottlebody port matched. $120
oil catch can mod done with fittings already installed.
carbon fiber spark plug cover w/stock. $80
EK and DC driver side bracket depending on what you want to throw the motor in.
no shift linkage.
remember 0 U.S. miles and i can start the motor up for you if you can make it before i pull it out.
local pick up please.
MAKE OFFER. NO LOWBALLERS. IF YOU READ BUMP.
THANKS.
no shift linkage.
THANKS.
gsr336
Southeast (Sales)
Oct 11, 2008 09:07 PM
