Battery Problems!!! Please Help Me H-Ters'
Old Nov 6, 2006 | 05:23 PM
h22xcivic's Avatar
Default Battery Problems or Alternator!!! Please Help Me H-Ters'
I got a stock 98 Hatch with a AEM intake. I just recently bought a new battery and my car is still dying on me. the light flashes on and off when i'm driving and sometimes stays on until i shut it off. everything was fine for about 2 days then this happened. can anyone tell me what my problem is? could it be my alternator? I also have a sound system, could it be this also?
update: when i turn on all my switches and stuff my kind of bogs like it wants to die but is hanging on to her life. is this a sign of the alternator?
Modified by h22xcivic at 10:04 PM 11/6/2006
Modified by h22xcivic at 12:03 PM 11/8/2006
Old Nov 6, 2006 | 05:35 PM
b18cEK's Avatar
Default Re: Battery Problems!!! Please Help Me H-Ters' (h22xcivic)
could be the alternator... take it off and autozone will test for free
check all connections for your system to make sure the battery is not getting drained from that... Also make sure the remote for the amp is wired into the radio, so it only turns on when the car is on
Old Nov 6, 2006 | 05:40 PM
Andres-eh2's Avatar
While the car is running disconnect the positive from the battery. Most likely it will shut off because it sounds like your alternator is dead. Does the belt sqeek? do the lights dim with the bass from the music??
Old Nov 6, 2006 | 05:43 PM
95jeremie's Avatar
what is your sound system setup?
watts?
check your alternator wires
Old Nov 6, 2006 | 06:59 PM
h22xcivic's Avatar
i dont know how my system is connected but i got a 10" W12 with a sony 600 watt amp. i dont think its the system becuase when im driving i shut off my stereo completely. and also the clock on my radio is off too...usually its still on when you turn it off.
i dont get no squeeks or anything like that....it kind of just slowly loses life.
but when i jumpstart it with a cable it starts fine, but again slowly loses life....what can it be? any one else got suggestions?
i hope its just the alternator!!!
Old Nov 6, 2006 | 07:01 PM
h22xcivic's Avatar
Default Re: (Andres-eh2)
will it help if i just disconnect the radio wire thats connected straight to the battery?
Old Nov 6, 2006 | 07:32 PM
95jeremie's Avatar
Default Re: (h22xcivic)
why is you radio wires straight to the battery? who installed it? sounds like that might be your problem. off the back of the radio what color wire is ran directly to the battery? what type of head unit (cd player)? of the power wires on the back of the cd player
red= 12 volt constant wire
yellow= 12 volt ignition wire
black= ground wire
solid blue or blue with white stripe= amp remote wire
Old Nov 6, 2006 | 07:37 PM
stock_honda_coupe's Avatar
Default Re: (95jeremie)
His amp is should be hooked directly up to the battery. Just go get the altinator checked. Or get a multimeter and do what you can yourself.
Old Nov 6, 2006 | 08:53 PM
h22xcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">While the car is running disconnect the positive from the battery. Most likely it will shut off because it sounds like your alternator is dead. Does the belt sqeek? do the lights dim with the bass from the music??</TD></TR></TABLE>
when my bass hits the lights dim on my headunit...and when i turn on the headlights and higbeam and stuff my radio shuts off and my car starts to bog alittle. so is it my alternator???
Old Nov 6, 2006 | 08:55 PM
h22xcivic's Avatar
Default Re: Battery Problems!!! Please Help Me H-Ters' (ej8pwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8pwr &raquo;</TD></TR><TR><TD CLASS="quote">could be the alternator... take it off and autozone will test for free
check all connections for your system to make sure the battery is not getting drained from that... Also make sure the remote for the amp is wired into the radio, so it only turns on when the car is on</TD></TR></TABLE>
now how hard would it be to change an alternator by yourself....im ok around cars, but it looks really ahrd to get to??
Old Nov 7, 2006 | 05:20 AM
Andres-eh2's Avatar
if you have little hands and patience its not a big deal. remove 2 bolts and its off
Old Nov 12, 2006 | 05:22 PM
h22xcivic's Avatar
bump
PhoenixDownVII
Dec 19, 2009 07:43 PM
SdAhd83
Aug 20, 2002 05:45 PM
Teal95Coupe
Jul 30, 2002 02:20 PM
