95 ex electrical help
Old Nov 6, 2006 | 12:33 PM
beefjerky's Avatar
Default 95 ex electrical help
okay heres what happened. was drving and everything was working fine. i stopped at a stop light and was getting ready to turn. then i noticed my turn signal ddint work and all mycluster gauges didint work as well. . i dont know what the problem is so help would be appreicated ...i dont want to pay 120 somehting dollars to get it fix if you guys know what i mean and how to fix the problem
Old Nov 6, 2006 | 02:10 PM
hongqun's Avatar
Default Re: 95 ex electrical help (beefjerky)
check the fuses first
Old Nov 6, 2006 | 03:03 PM
Relic1's Avatar
the only common element between the gauges and the turn signal lights is the ground to the cluster.
the turn signal lights get power from the blinkers, the gauges get power from the key.
Could be the connectors on the back of the cluster came off partially.
Old Nov 6, 2006 | 05:14 PM
beefjerky's Avatar
Default Re: (Relic1)
i did check the fuses..none were blown. also there doesnt seem to be a gauge cluster fuse or turn siganl fuse? so should i just pay the money to get it doen professionally?
Old Nov 6, 2006 | 05:50 PM
Andres-eh2's Avatar
i believe if the hazard switch it disconnected or broken for that matter the turn signals wont work. look into that
Old Nov 7, 2006 | 05:55 AM
beefjerky's Avatar
Default Re: (Andres-eh2)
the thing is hazard switch works fine.....
Old Apr 23, 2007 | 08:52 AM
chuckc417's Avatar
Default Re: (beefjerky)
did you ever find out what the problem was, i am having the same problem, and i can not find the problem anywhere
Old Apr 25, 2007 | 01:23 PM
chuckc417's Avatar
Default Re: (chuckc417)
I fixed it...Sweeeeeeeeeeeet
Old Apr 4, 2022 | 05:44 AM
curt0526's Avatar
@chuckc417 what was the issue? I’m having the same problem myself with my 95 ex coupe….no cluster and turn signals aren’t working at all.going over the fuses again when I get off but I’ve replaced a lot of them already
Jalexck
Mar 22, 2014 07:26 PM
b18-boy
Apr 29, 2008 06:08 AM
Jay.D.Em!
Apr 17, 2006 07:17 PM
jedubz
Aug 18, 2005 12:56 PM
EGTeK
Mar 26, 2003 10:52 AM
