JDM CTR Pistons/Cams better than USDM ITR Pistons / Cams?
CTR pistons will raise compression at least one full point higher than OE USDM. Fuel and timing issues must be address. If not.... https://honda-tech.com/zerothread?id=179576 !
The 00/01 USDM ITR cams are the same as the CTRs. Only difference over 97-98 is intake cam has 2-3 deg more duration.
Tuning is key!
Tuning is key!
