Tps sensor
Old Nov 6, 2006 | 09:53 AM
WalkerGSR1's Avatar
Default Tps sensor
does the tps sensor have to have that gasket on there? i cant find anywhere that sells the gasket.
Old Nov 6, 2006 | 12:31 PM
WalkerGSR1's Avatar
bump
Old Nov 6, 2006 | 12:35 PM
HoUTX98GSR's Avatar
Default Re: (WalkerGSR1)
if you cant find one get one of those do-it-yourself gasket kits. You just cut out the gasket that you need.
The first time i pulled a throttle body i forgot to get a new gasket (car was my daily driver). I was like "****!", and i ran upstairs and asked my friends dad what to do. I tried liquid gasket and it leaked. He said "Son, let me take you through gasket making 101". He took the back of a notebook spiral (you know, the brownish yellow cardboard piece) and traced the throttle body onto it and cut it out. Worked like a charm, but i did end up buying the gasket and replacing it later.
You might try that. If it leaks youll get a surging idle.
Old Nov 6, 2006 | 12:44 PM
WalkerGSR1's Avatar
where did you buy the gasket?
Old Nov 6, 2006 | 01:06 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Tps sensor (WalkerGSR1)
Since Honda does not sell the TPS independent of the TB, they do not sell a TPS gasket. You will need to fabricate a gasket.
Old Nov 6, 2006 | 02:05 PM
HoUTX98GSR's Avatar
Default Re: Tps sensor (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Since Honda does not sell the TPS independent of the TB, they do not sell a TPS gasket. You will need to fabricate a gasket.</TD></TR></TABLE>
Thats what i meant to say.. honda doesnt sell the TPS seperate..
But yeah, you can get one of those do it yourself gasket kits from an auto parts store..
(btw the gasket i bought wasnt the TPS gasket, it was the TB gasket. You will have to fabricate one like Dogginator said.)
Old Nov 6, 2006 | 02:15 PM
skunked's Avatar
Default Re: Tps sensor (HoUTX98GSR)
you don't really need a gasket. Just a little RTV silcone or Honda bond does the trick
Old Nov 6, 2006 | 04:20 PM
WalkerGSR1's Avatar
rtv silicone sounds alot better.
Old Nov 6, 2006 | 04:38 PM
qfast817's Avatar
i used hondabond
Old Nov 7, 2006 | 01:41 PM
TheGreenOne3589's Avatar
do it yourself gasket should be fine
bdr_one
May 9, 2015 10:02 AM
EJ1_203
Jan 24, 2006 08:19 PM
civic_driver
Sep 25, 2005 11:51 PM
JDMCivicEF9
May 7, 2005 10:47 PM
frenchy
Jun 7, 2004 02:28 PM
