Suspension & Brakes Theory, alignment, spring rates....
HELP- Stock spring perch with Koni install.
Old Nov 6, 2006 | 05:37 AM
b18LS's Avatar
Default HELP- Stock spring perch with Koni install.
Hi, can I use a perch from a stock integra shock, on my Konis? The konis are on the car right now, and Im running G/C coils. Im switching to lowering springs and need a perch again. If so, how do you remove them from the stock shock. Im guessing the ridges need to be ground down. any help is appreciated. If all else fails I know I can order them from koni
Old Nov 6, 2006 | 09:05 AM
Tyson's Avatar
Default Re: HELP- Stock spring perch with Koni install. (b16gs)
no. totally unseparable on stock and specific to koni.
order them from koni.
Old Nov 6, 2006 | 03:05 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: HELP- Stock spring perch with Koni install. (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16gs &raquo;</TD></TR><TR><TD CLASS="quote">Hi, can I use a perch from a stock integra shock, on my Konis? The konis are on the car right now, and Im running G/C coils. Im switching to lowering springs and need a perch again. If so, how do you remove them from the stock shock. Im guessing the ridges need to be ground down. any help is appreciated. If all else fails I know I can order them from koni</TD></TR></TABLE>
Dude, don't do it. Why are you going to go to a normal spring? Trust me, you will regret it.
Old Nov 6, 2006 | 05:17 PM
b18LS's Avatar
Default Re: HELP- Stock spring perch with Koni install. (JDM_Ej)
Well, theyre Koni reds, and Its more of a daily driver than a track car. I miss my proggressives. Coilover springs no matter the quality always ride stiff. Its not bad over ripples, but a solid ridge or dip in the road, will have you gritting your teeth. The car just feels angry to drive. I need a change.
808dc2typer
Suspension & Brakes
10
Sep 4, 2015 05:05 AM
bopbop93030
Suspension & Brakes
Jan 19, 2009 05:14 AM
stock99
Suspension & Brakes
Nov 1, 2005 07:04 PM
speedevo
Sep 8, 2003 05:47 PM
Disco Monkey
Oct 11, 2001 07:35 AM
