15" vs 16" lightweight (searched)
i have 15" wheels which weight 22lbs each. I want to switch to 16" lightweight SSR integral A2 which weight 13lbs. how will this affect speed if the overall diameter (tyre + wheel) doesnt increase much? theoriticaly it will reduce the unsprung weight right?
Any type of experience is apritiated
to maintain same diameter when switching to bigger wheels you must reduce tyre height. i want to know which setup is faster: 205/50/R15 (22lbs rim) or 225/45/R16 (13lbs rim)
Modified by beqa16v at 5:52 AM 11/6/2006
well 205/50/15 is not a stock diameter
225/45/16 is very close to stock and it is what i run
i guess if you are asking for acceleration purpose then you would be able to accelerate faster with the smaller 205/50/15
but if you wanted the lighter 16 with a smaller diameter then you could go 205/45/16......it would be about the same as the 205/50/15 which neither of are stock diameter
205/55/15 is stock for 4th gen, if you run a 205/50/16 you have the same.
205/50/16 = 205/55/15
Speedo will still be the same.
I have Potenza's on Slips.
205/50/16 is higher than 205/55/15. i'm runing 205/50/15 now. 13lbs wheel instead of 22lbs. so it will not be enough for faster acceleration? doesnt that unsprung weight factor matter?
guys what is the point of this retarded argument
1)use a tire size calculator and stop speculating over whats bigger and smaller....
http://www.miata.net/garage/tirecalc.html
2)of course lighter wheels = faster car...duh
You could mount up both and get the wheel spinning at a set rate, then time how long it takes for the wheel to slow down.
The faster wheel will be faster.
No matter what the lighter wheel will have a lighter un sprung weight.
GM Killer
Mar 18, 2002 07:04 AM
Dirt
Oct 24, 2001 08:31 AM
