lights dimming with a new alternator
Old Nov 5, 2006 | 09:18 PM
El pimp chulo's Avatar
Default lights dimming with a new alternator
i just got a new alternator and my lights still dim out when i lef off the gas is this an EF thing or what else can it be?thnx
Old Nov 5, 2006 | 09:54 PM
EF Durty MX's Avatar
Default Re: lights dimming with a new alternator (El pimp chulo)
u got a new alternator and it still does that? hmm... well to answer "is this an ef thing" yeah mine does it too but i think my alternators bad and i got a spare but im too lazy to replace it right now, and the fact that the motors coming out in about a month so im not too worried about it. everybody says the alternator is why mine does that tho but if you replaced it and it still does it i wonder what else it could be. sorry i couldnt help out but jus givin input. bump for answers!
Old Nov 5, 2006 | 10:08 PM
bunburyd16y's Avatar
i had the prblem 3 days ago until i got a new alternator,
what i did was the following
i change the alternator my light s kept dimin off
with the new alternator so i decided to check
the cables that connect to the alternator, one of them is a ground cable.(it runs to the fuse box inside engine compartment passenger side) i notice it was not tighten so i grab a scre and plug that cable turn my car on and it solved the problem.....................
in short words check you ground cable that runs from the alternator to the fuse box
Old Nov 5, 2006 | 10:37 PM
ef 4 door's Avatar
Default Re: (bunburyd16y)
good point to always double check all your connections. look at the alternator and also double check that your battery is fully charged. this happened to me last month. I had a bad battery with a new alternator. also diming lights and then replaced my battery then everything is a ok.
Old Nov 6, 2006 | 07:32 PM
Default Re: (ef 4 door)
I charged my battery and gotit tested it does it a bit less now but it still does someone said maybe its the fuse box under the hood to change a sensor or soemthign in it or change the whole thing
Old Nov 6, 2006 | 08:17 PM
ef 4 door's Avatar
Default Re: (El pimp chulo)
Now when do u notice the dimming of the lights. Do you have the alternator under load. check the voltage on the battery witha DMM with your ligths and high beams on. also your heater at full blast and the wiper going. you should get a voltage reading of 13.5 to 14.5 volts.
let me know what you get?!
Old Nov 9, 2006 | 07:44 AM
I figured it out i was just idling too low i was idling at about 500 so i tuned it too idle at 1000 and its works great no more dimming
Old Nov 9, 2006 | 09:39 AM
ef 4 door's Avatar
good job @ diagnois of the problem!
Bradford86
Honda Civic (2001 - 2005)
Mar 5, 2019 11:13 AM
W95civicEXcoupe
Apr 1, 2015 12:29 PM
whitehf
May 10, 2007 08:40 PM
Nandy
Jul 20, 2006 06:50 PM
92silude
Jun 14, 2005 12:11 PM
