94 integra smoke question
Old Nov 5, 2006 | 09:17 PM
kenny7231's Avatar
Default 94 integra smoke question
I have a 1994 GSR. my friend said it smokes white when i get on it but stops when i get off the gas. so i checked it out and when i smell by the exhaust it smells like pure gas/ running rich what would cause this problem. i took the plugs out and no oil on it!!!!! so im wondering what would cause this thanks in advance for your help
Old Nov 6, 2006 | 04:15 AM
96lude_srv's Avatar
white smokes usually indicates that its burning coolant. Could be your head gasket.
Old Nov 6, 2006 | 08:20 AM
kenny7231's Avatar
thanks ne one else ?
Old Nov 6, 2006 | 07:43 PM
bennyDA's Avatar
Default Re: (kenny7231)
is it cold out? lol ud be suprised how many people think they got a leaky head gasket when its just the temp change
White Smoke=head gasket
Old Nov 6, 2006 | 11:55 PM
Dealer Leaf's Avatar
Default Re: 94 integra smoke question (kenny7231)
I get the same thing on my 1991 Integra LS. It only happens when I get off night shift not on the drive there. The cold seems to produce alot of smoke
Old Jul 31, 2011 | 05:09 PM
gsr4door617's Avatar
im tryna figure this out on mine buddy says a valve
Old Jul 31, 2011 | 07:58 PM
eclipsedsundown's Avatar
what color were the plugs, where they a chalky white. That means you are running to rich or your plugs are burning to hot. Iridium doesn't equal fast! How many miles are on it? Do you have a high flow fuel pump, adjustable fuel pressure regulator? Let us know.
Old Aug 1, 2011 | 01:52 PM
i gota stock gsr havent upgraded any fuel or aanything alll i did was try a chipd ecu on it and went around the block changed the comp adn thing wouldnt stay on with out pressin gas an dmadd smoke came out the tailpipe with the strongest gas oder ever
Old Aug 1, 2011 | 02:04 PM
you said you switched the ecu and drove it around the block, and did you switch the ecu back to stock and that is when this started happening? If you are still running a chipped ECU then the rest of your stock fuel system is trying to compensate for the new fuel charts.
mcnos
Nov 29, 2010 07:01 PM
JunkyardAccord
Nov 18, 2008 10:11 AM
PRIMITIVEALLMOTOR
Engine Management and Tuning
Aug 23, 2008 01:44 PM
vtec4u92
Apr 1, 2006 12:15 AM
