NEED input on planned swap
Well here in goes. I got a 91 hatch DX. I am planning on build a ZC on Boost. I plan on building the bottom end. Eagle Rods, Weisco Pistons, new bearings. I am also get the wiring done for the MPFI.Has there been problems. Anything input can help. PLEASE
i'd do your mpfi swap first if you already got your manifold, that way you can make sure that works before you start doing your turbo. need more info though, what turbo and manifold you gonna put on it? turbo zc sounds sweet though!
Im planning on getting a manifold from Godspeed. It has a T3 flange, then putting on a T28 turbo. Also getting a godspeed intercooler kit. For the fuel I figured 450cc injectors, a fuel pump,aem rail, and pressure regulator.
