Dash removale and remote start install
Old Nov 5, 2006 | 06:14 PM
iceman7329's Avatar
Default Dash removale and remote start install
Im taking the dash out of my 94 Civic LX 4 door. Any tips or anything I should know to save me any headaches? Normally Id just jump in and do it but its cold outside now.
Im also installing a remote start system that rolls the windows up with the alarm and all that stuff. Any tips? Ive never done one but I can do it, I can do anything I set my mind to.
Old Nov 5, 2006 | 07:47 PM
f20bej1's Avatar
Default Re: Dash removale and remote start install (iceman7329)
time consuming but just take your time its not difficult just frustrating
Old Nov 5, 2006 | 08:22 PM
ethiks313's Avatar
heres all the wire colors for your car. what i usually do is find and test all the wires with a computer safe meter first, then start making connections, but I leave the battery+ connections for last.
12volts
white
steering column
Starter black/white + steering column
Second Starter
Ignition black/yellow + steering column
Second Ignition
Third Ignition
Accessory yellow + steering column
Second Accessory
Keysense
Power Lock green/white - 2pin plg blue-taped to
Power Unlock green/red - blue plg behind f-box
Lock Motor
Unlock Motor
Parking Lights+ red/black at fuse box or d.k.p
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger lt. green/red - driver kick panel
Dome Supervision
Trunk/Hatch Pin grn/blk 2 sil.dot - blue conn. above fusbx
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue AC 2-pin conn. near dist.
Wait to start
Brake Wire green/white + at brake switch
Parking Brake
Horn Trigger blu/grn, blu/red - at steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
nandrus
Audio / Security / Video
15
Jun 2, 2012 12:33 PM
137
Mar 17, 2008 07:23 PM
ProjectEJ2
Jul 31, 2007 08:40 AM
JDMCivicHatch93
Jun 16, 2003 09:02 AM
BoostedH23a1
Oct 29, 2002 09:35 AM
