dx model crx
Old Nov 5, 2006 | 05:51 PM
EFan's Avatar
Default dx model crx
How are you guys? I have an hf crx swapped. It came with the four injectors, but the dx model only two. Lets even say I was putting an Si motor in a dx. Would I just be able to use the Si wiring hareness and all injectors will work also with the Si ecu. I have heard of how you wire it up ,and run all injectors with the dx wiring harness. But I just want to know if everything would work right with the Si harness. Im not doing this swap with a dx, I just used it for example. Thanks for the info.
Old Nov 5, 2006 | 07:18 PM
nappyroots827's Avatar
Default Re: dx model crx (EFan)
HF swapped? with what??
P.S. what the hell are you trying to do?
Old Nov 5, 2006 | 07:37 PM
Tippyman's Avatar
do WHAT?
The search button works for trial users. Use it.
Old Nov 5, 2006 | 08:17 PM
NikoZai's Avatar
Default Re: (Tippyman)
probably means DX to HF conversion.
The wiring can be found here:
http://rywire.com/store/8891-c....html
(yes it says dx to d16a6, it's the same thing as a HF engine as far as the wiring is concerned)
Old Nov 6, 2006 | 04:18 AM
EFan's Avatar
Default Re: dx model crx (nappyroots827)
What Im trying to say is the dx is dpfi. Can you just take an Si motor "mpfi" with the wiring harness and drop it right in without modifying the Si harness?
Old Nov 6, 2006 | 04:45 AM
crxben's Avatar
Im pretty sure you can just modify your dx harness to work with the d16a6 motor. If you search DPFI to MPFI this will help you out. Also you need to switch more on your dx then just the motor. Axels, shift linkage and there is more, but its not hard.
Old Nov 6, 2006 | 08:36 AM
Default Re: dx model crx (crxben)
if you have a dx right meow and you want to switch to a si motor, its much easier to just modify your dx harness....search, there are questions about this every five minutes, there are thousands of posts about this conversion
harmonator84
Nov 11, 2005 07:09 AM
deftones0817
Jun 5, 2004 08:28 PM
AVXHATCH
Apr 28, 2004 01:55 PM
Big Bang
Aug 18, 2003 07:50 AM
hfracer420
Feb 12, 2002 07:54 AM
