syncrowave 200 and aluminum
Old Nov 5, 2006 | 05:39 PM
dfoxengr's Avatar
Default syncrowave 200 and aluminum
so ive spent most of my welding time on a sync 250 here at VT which has probably spoiled me because AC on it has a cleaning pass feature which my at-home 200 doesnt.
i tried welding some cast aluminum the other day, cleaned with acetone and ss brush and i couldnt get a whole bead to come out without inclusions. the 250 always welds really clean even when i dont clean Al as well.
i didnt mess with the settings on my 200 and i couldnt find my owners manual to do so.
so does anyone have any tips on how to keep it clean?
-derek
Old Nov 5, 2006 | 08:25 PM
Bjorn's Avatar
haven't welded cast but tried to polish it - you have to grind down deep because the pores trap a lot of crap - I had to go down ~3/32" to find non-porous clean metal on an im
Old Nov 5, 2006 | 09:41 PM
AspectIndustries's Avatar
Default Re: (Bjorn)
I would like to know also.
Old Nov 6, 2006 | 07:10 AM
onefstek's Avatar
I welded a trany the other day and the first pass was a bit dirty. But as soon as the aluminum got got, the next pass was working verry well.
I had the amps about 180, the gas at about 18 cfm's and used the green tungsten.
Old Nov 8, 2006 | 06:07 PM
dfoxengr's Avatar
Default Re: syncrowave 200 and aluminum (dfoxengr)
anyone?
Old Nov 9, 2006 | 08:16 AM
SQ is the SQUAD's Avatar
not sure on the setting but if you go to the miller site that should have the manual for your machine. i also have a 200 so if its something you need me to look for in the manual just pm me
Old Nov 9, 2006 | 11:19 AM
dfoxengr's Avatar
Default Re: syncrowave 200 and aluminum (SQ is the SQUAD)
yeah i lost my manual somehow
im jsut curious on others' methods for welding cast with this machine.
Old Nov 9, 2006 | 02:28 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
u generally have to keep the puddle molten for longer periods of time in order to let the slag bubble up and out of porous cast al. circle around for a while with a little less heat input and see if it cleans up. if you cant do it in one pass, try a first pass of torch only and a second pass of filler material.
Old Nov 9, 2006 | 02:35 PM
dfoxengr's Avatar
Default Re: (mike_belben@yahoo.com)
ill try that. thanks.
-derek
Old Nov 10, 2006 | 01:27 PM
MajorPayne's Avatar
Default Re: (dfoxengr)
its also preferred that you heat the cast aluminum prior to welding in order to "properly" weld it...you can do it without pre-heating it, but it is likely to get stress cracks
Old Nov 10, 2006 | 01:56 PM
dfoxengr's Avatar
Default Re: (MajorPayne)
assuming it is a stressed part.
PinkMaggit
Welding / Fabrication
Sep 7, 2006 08:16 PM
