what would cause this
Old Nov 5, 2006 | 11:00 AM
Felt.2's Avatar
Default what would cause this
i searched to so dont even. my h22 delsol seems to run good for the first 15min. while driving then the car begins to bog and doesnt respond like lack of power but my ignition is fine. i got fuel i dont have any(cel) does this sound like a un calibrated tps sensor. the car is also running rich real rich. im stummped
Old Nov 5, 2006 | 11:02 AM
EX2SI's Avatar
Default Re: what would cause this (Felt.2)
could be a ground issue... Or maybe your iacv is not working 100% and is making you run in warm up mode?
Old Nov 5, 2006 | 11:10 AM
Felt.2's Avatar
Default Re: what would cause this (EX2SI)
well the car spits rich wettish black smoke upon startup and idles a little ruff. my iavc is screwed all the way down < previous owner. would that make it run in warm up mode.
the car is a well done swap cause me and him did it about 3 years ago. it just started doing this after i adjusted the idle screw on the throttlebody to bring the idle up a little.
now it just runs rich and acts a fool when i step on it
Old Nov 5, 2006 | 11:11 AM
Rock Meathammer's Avatar
What injectors and ecu are you running?
Old Nov 5, 2006 | 11:23 AM
Felt.2's Avatar
Default Re: what would cause this (3 Dough)
its a chipped p28 with oem prelude injectors and resistor box.
a. bad tps sensor<could be sending the wrong voltage causing bad fuel to air ratio?
b. bad distributer< but car runs fine and idles fine once warm
c. jumped a tooth or two < would that cause such bad aceleration
d. i need a bigger hammer
Old Nov 5, 2006 | 12:48 PM
Skunk.Werks's Avatar
Set TPS to OEM specifications,
Check condition of plugs and replace/regap if needed
Get engine to operating temperature, jump the diagnostic plug underneath glovebox (if you have one) to set base idle and timing. Idle should be about 600-750 with jumper in, make sure your fans are not running while setting idle.
Also while that jumper is still in, check and reset timing if neccesary. Jumper is required for when you clock the distributor so the timing actually changes and the ECU doesn't auto-correct while you are setting it.
You could also try replacing the dizzy cap and rotor if you feel daring.
Old Nov 5, 2006 | 01:05 PM
Felt.2's Avatar
Default Re: what would cause this (Skunk.Werks)
well ive been messin with it and vtec does not kick in either so im wondering if it is a timming issue cause the car seems to be getting enough fuel
Jeremiah Velez
Engine Management and Tuning
Nov 3, 2017 04:46 PM
civicracer1997
Apr 18, 2012 10:37 AM
s032105k
Apr 12, 2011 10:14 AM
khcivic
Feb 11, 2003 06:37 PM
