Custom Cutting EK Front Bumper?
Old Nov 5, 2006 | 05:40 AM
TunerShark's Avatar
Default Custom Cutting EK Front Bumper?
this is what im talking about
has anyone on here done this before? how did you do it?
Old Nov 5, 2006 | 05:50 AM
Vero's Avatar
Default Re: Custom Cutting EK Front Bumper? (TunerShark)
dremel with a cut-off wheel, bloock sander, and a file
Old Nov 5, 2006 | 05:58 AM
TunerShark's Avatar
Default Re: Custom Cutting EK Front Bumper? (Vero)
thats what i was thinking, the bottom grille doesnt just pop out or unscrew though does it? so its molded to the bumper?
Old Nov 5, 2006 | 06:03 AM
slambedcivic's Avatar
^ Correct. if you dont have a dremel available. ive used tin snips and a fileto clean the edges
Old Nov 5, 2006 | 06:15 AM
Eran's Avatar
HT White Ops
I've used a steak knife and a file, and then some 600, then some 1000 grit.
Old Nov 5, 2006 | 08:54 AM
igo4bmx's Avatar
i've used a pair of strong *** scissors too...
just make sure to sand so it looks clean.
Old Nov 5, 2006 | 10:17 AM
Kruzen510's Avatar
Default Re: (igo4bmx)
any of therse will work, I use a die grinder then sandpaper to clean it up. good luck, maybe make a line with tape around it so you get a straight cut.
Old Nov 5, 2006 | 01:00 PM
Taimaishui14's Avatar
Default Re: (Kruzen510)
Pretty much the same procedure as if you made your own CTR grille.
Old Nov 5, 2006 | 01:10 PM
cambopheonix56's Avatar
Default Re: (Taimaishui14)
LMAO, interfooler
Old Nov 5, 2006 | 01:18 PM
dem0nk1d's Avatar
Default Re: (cambopheonix56)
your best bet, is not to use a cut off wheel. it will only burn and melt the plastic. I have always used a metal cutting blade. I use a body saw. Or if you don't ahve access to a neumatic bodysaw. Use a jig saw...
Old Nov 5, 2006 | 01:23 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">LMAO, interfooler </TD></TR></TABLE>
Looks more like a backdoor setup to me. You can see some more t-bolt clamps behind the bov.
Old Nov 5, 2006 | 01:26 PM
Eran's Avatar
HT White Ops
Default Re: (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">Looks more like a backdoor setup to me. You can see some more t-bolt clamps behind the bov.</TD></TR></TABLE>
I've seen more pics of that car. It is a backdoor setup.
Old Nov 5, 2006 | 02:46 PM
dem0nk1d's Avatar
WTF is a backdoor setup?
Old Nov 5, 2006 | 03:02 PM
John M's Avatar
Default Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">WTF is a backdoor setup?</TD></TR></TABLE>yeah....
i thought it was called a backyard special???
Old Nov 5, 2006 | 03:07 PM
EK k kay's Avatar
Default Re: (Teal-EJ1)
Old Nov 5, 2006 | 03:20 PM
TunerShark's Avatar
thats actually an 850 whp H22 Hatchback, the one that was in this months honda-tuning mag. http://www.hondatuningmagazine...turbo/
anyways, when i get my turbo setup i plan on cutting it, just to show off the Intercooler lol. plus it looks 10,095935432,32434543x better
Old Nov 5, 2006 | 03:23 PM
99blackcivicSi's Avatar
Backdoor setup is for no charge pipe froming form the turbo, the turbo uses just one coupler to go right to the intercooler.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teal-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">yeah....
i thought it was called a backyard special???</TD></TR></TABLE>
yeah if it was that rediculously expensive bumper everyone drools over but thats not hte case read above
Old Nov 5, 2006 | 04:10 PM
VRD^don's Avatar
Default Re: (99blackcivicSi)
i used a jigsaw..but with a finner blade....cuts the bumper like butter..
Old Nov 5, 2006 | 05:49 PM
ExSohcEk's Avatar
Default Re: (k_motor)
LMAO @ you....that cars on the cover of Honda Tuning. 852whp H22-t. good eye though.
Old Nov 5, 2006 | 06:05 PM
dafuzzbudd's Avatar
Default Re: (ExSohcEk)
does the bumper grill block a noticable amount of airflow to the intercooler?
Old Nov 5, 2006 | 06:44 PM
mulletov's Avatar
u can use a close quarter hacksaw. when i installed my foglights, i just used the hacksaw blade by itself. works good and cuts real easy.
Old Nov 5, 2006 | 06:47 PM
Archidictus's Avatar
Unceasing Measure
If stupid caused pain, you'd be in shock right now, champ
Old Nov 5, 2006 | 06:52 PM
Eran's Avatar
HT White Ops
Default Re: (dafuzzbudd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dafuzzbudd &raquo;</TD></TR><TR><TD CLASS="quote">does the bumper grill block a noticable amount of airflow to the intercooler?</TD></TR></TABLE>
I imagine it does when you've got a backdoor setup that ti'ts out the mouth.
Old Nov 5, 2006 | 06:53 PM
1 2 NV's Avatar
i doubt it, people just want to have the bling bling intercoolers showing.
Old Nov 5, 2006 | 06:56 PM
Unceasing Measure
Not enough to keep it from making 850+ hp...so I'd say no. No it doesn't.
