Rough idle on cold start...
Old Nov 4, 2006 | 11:33 PM
square_1's Avatar
Default Rough idle on cold start...
When I start my car in the morning it idles REALLY rough. Actually anytime I start my car when it has been sitting for a while. Even in the day time. Like I am pretty sure it is missing on the idle. It has new plugs, is it just a normal thing for an older motor?
Thanks...
Old Nov 5, 2006 | 06:30 AM
ED6JDM's Avatar
Default Re: Rough idle on cold start... (square_1)
I have this problem as as well. If the car sits for more than 6hrs or so, I can't start the car and drive right away. All of the time I have to let the car warm up about 10mins before driving. It's a new motor!
Old Nov 11, 2006 | 07:06 PM
square_1's Avatar
Default Re: Rough idle on cold start... (ED6JDM)
Anyone???
Old Nov 11, 2006 | 07:22 PM
over_'s Avatar
check timing??
Old Nov 12, 2006 | 03:16 AM
Duane_in_Japan's Avatar
Default Re: (OVNI_CIVIC)
Pull one plug wire at the head and see if the idle gets worse or stays the same, put it back on and pull the next one and let us know what happens. Next spray some carb cleaner into the air filter box and see if the engine runs better, spray some around the intake to head gasket area and see if it gets better, let us know please.
Old Nov 12, 2006 | 10:13 AM
RockinthEFhatch's Avatar
It's the FITV in your throttle body, just get a new throttle body or an aftermarket one will remove that completely. I'm selling one for a B series if interested.
heinrichranches
Oct 19, 2015 08:57 PM
sevenfc
Mar 18, 2009 03:26 AM
Maireeka
May 31, 2007 08:27 AM
Iron_Forrix
Oct 24, 2006 12:37 PM
TypeRKoncepts
Mar 4, 2005 04:24 PM
