EP3 IDLING PROBLEM AFTER INTAKE SWAP?!!?!?
Old Nov 4, 2006 | 10:20 PM
kidd_drastic's Avatar
Default EP3 IDLING PROBLEM AFTER INTAKE SWAP?!!?!?
I recently replaced my stock intake with an AEM cold air. I plug in the sensor that was on the stock intake arm into the whole made for it. My idle sucks and gets stuck at 2000rpm and when i let my foot off the gas the throttle sounds like it closes. Any inpuit??!??!?!?!
Old Nov 5, 2006 | 09:46 AM
NeWnMpR0VeD's Avatar
daaaaaaamn daniel, u have an EP3 now !?!?
movin up in the game ?
Old Nov 5, 2006 | 12:27 PM
Default Re: (NeWnMpR0VeD)
naw hahah its for my friends car.
Old Nov 5, 2006 | 09:26 PM
k20EP3's Avatar
Default Re: (kidd_drastic)
sounds like something didn't go back where it was supposed to... recheck everything over again
Old Nov 6, 2006 | 02:38 PM
K20-R EP's Avatar
try resetting the ecu. just take out the fuse for 10 seconds.
is there any cel?
Old Nov 6, 2006 | 03:03 PM
typeRaccord's Avatar
Default Re: EP3 IDLING PROBLEM AFTER INTAKE SWAP?!!?!? (kidd_drastic)
hmm...
gay AEM, never makes anything that fits, i got the same intake and i had to cut a few things to make it fit. Especially the fulid container...had to do some trimming to make it all fit. When did u install ur aem, it usually takes about 10-20 miles after installation to get ur idling back to normal. Drive it around for a bit and see if that helps, if not, you might wanna re-check ur install. Good luck wth that
mynameizstitch
Jun 26, 2009 06:07 AM
iCollectStraws
19
Jan 2, 2009 06:12 AM
TunerShark
Sep 29, 2006 07:21 AM
NaSh123
Dec 7, 2003 08:21 AM
reVVin
Apr 7, 2002 08:20 AM
