Honda S2000 Honda S2000
Question for all the hardtop owners out there....
Old Nov 4, 2006 | 08:03 PM
IlladelphSi's Avatar
Default Question for all the hardtop owners out there....
Recently i've developed some sort of phantom squeek from where the hardtop latches to the striker near the windshield. This is mostly on the passenger side, but occasionally on the drivers side. It's a very sharp/short high pitched squeek that only occurs when the car is jarred or i'm driving over a bump or something. It's basically driving me insane at this point. I've tried lubing the **** out of the latch, and that didn't seem to do anything. Is there anything else I can do other then more lube? Maybe some sort of tightening or adjustment? I'm ready to resort to taking it to the dealership at this point.
Old Nov 4, 2006 | 08:09 PM
LAS2K's Avatar
Default Re: Question for all the hardtop owners out there.... (IlladelphSi)
theres a gap between the plastic things on the sides...put some sort of spacer in there. thats the rattle.
Old Nov 5, 2006 | 06:26 AM
papa5murf's Avatar
if the lube didn't work.. then just tighten it..
Old Nov 5, 2006 | 07:45 AM
Infinity_Racer's Avatar
Default Re: Question for all the hardtop owners out there.... (papa5murf)
try to readjust the top...if its a squeek then it should be the rubber pieces...but a rattle and a squeek are two different things.
Old Nov 5, 2006 | 07:53 AM
Francesco's Avatar
Default Re: Question for all the hardtop owners out there.... (Infinity_Racer)
open the front latches and re tighten the philips screws that hold it to the top. i had a spacer get loose once because the bolt was coming out. lock tight and a screw driver fixed that.
Old Nov 5, 2006 | 08:12 AM
Default Re: Question for all the hardtop owners out there.... (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">open the front latches and re tighten the philips screws that hold it to the top. i had a spacer get loose once because the bolt was coming out. lock tight and a screw driver fixed that.</TD></TR></TABLE>
I'll give this a try right now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">theres a gap between the plastic things on the sides...put some sort of spacer in there. thats the rattle. </TD></TR></TABLE>
huh?
s13hero
Dec 1, 2010 03:32 PM
tepid1
Paint and Body
Apr 9, 2010 02:15 AM
Markov
Jul 25, 2005 10:28 PM
Stinkycheezmonky
Jun 29, 2003 01:01 PM
