crooked motor...CRAP!!!
Old Nov 4, 2006 | 06:30 PM
MI4$DC5's Avatar
Default crooked motor...CRAP!!!
man, i just took out my stock d15 motor. which was sitting perfectly fine. Swapped in my b20 vtec using manual mounts and now the motor is crooked. expletive!!! Im using a cable tranny. I only have 3 mounts in. is the motor sitting crooked cause of the other 2, i dont see why it should be crooked, but it could be.
Old Nov 5, 2006 | 08:07 AM
locash's Avatar
Default Re: crooked motor...CRAP!!! (MI4EH2)
More information needed.
What car, was it originally an auto or manual, are you using OEM mounts or aftermarket?
Old Nov 6, 2006 | 08:32 AM
da egg's Avatar
was your car auto before?? if it was you'll need the auto to manual mount from inlinefour.com (tranny side mount)
Old Nov 6, 2006 | 09:44 PM
MI4$DC5's Avatar
Default Re: crooked motor...CRAP!!! (da egg)
the car is manual. i went to mess around with the car today and since im putting a b20vtec. do i use the integra drivers side mount and the bracket that connects to the engine block or can i use the b20. cast-iron bracket from any 1994-2001 Integra GS-R . i was looking at part numbers and the integra and crv have different part numbers.
Old Nov 10, 2006 | 03:25 PM
da egg's Avatar
use a rear mount from a DC teg.
Old Nov 10, 2006 | 06:55 PM
MI4$DC5's Avatar
thats what im using. what about the cast iron that holds the drivers side mount. should that be from a teg or can i use the b20
Old Nov 11, 2006 | 01:15 AM
Haza45's Avatar
If your speaking about the timing belt side you have to use a DC Mount and bracket or it will be crooked
Old Nov 12, 2006 | 10:37 AM
gsr converters's Avatar
when i put my gsr engine in my automatic civic sedan, i had to change out the passenger side mount and reweld another one in from another car
Old Nov 12, 2006 | 11:37 AM
MI4$DC5's Avatar
Default Re: crooked motor...CRAP!!! (Haza45)
yeah thanks, i got a dc one and its sitting good. one problem solved and 50 more to go..lol
Old Nov 12, 2006 | 06:50 PM
Haza45's Avatar
No problem. What else are you having issues with?
fletch00
Dec 6, 2013 12:39 PM
90teg91hatch
Aug 4, 2008 06:22 PM
blackfoot
Aug 28, 2007 08:29 AM
davidcrx89
Apr 21, 2006 10:10 PM
Si Integra
Mar 9, 2005 12:38 PM
