Check the pressure of the AC system?
Old Nov 4, 2006 | 06:27 PM
dawnriver's Avatar
Default Check the pressure of the AC system?
The pressure at the low pressure valve of my 93 Accord LX is zero, probably because of a leakage somewhere in the system. I don't have a gauge to test the high pressure valve. Does this mean the high pressure side is also zero? I haven't run the AC for over a year. Now I need to open the system and remove the condensor.
Thanks.
Old Nov 4, 2006 | 10:37 PM
Honda-Master's Avatar
Default Re: Check the pressure of the AC system? (dawnriver)
get a small screwdriver and push down on the valve on the a/c high pressure hose. if no freon comes out your system is most likely empty ...
but if low side is at zero most likely high side is at zero or close to it ..
Old Nov 5, 2006 | 02:29 AM
Duane_in_Japan's Avatar
Default Re: Check the pressure of the AC system? (Honda-Master)
When the AC System sits for awhile, the Lo & Hi side pressures equalize, you are empty due to a medium to a large size leak. You will need to do a leak test, locate all the leaks, fix the leak, change the receiver/drier and do a full vacuum and reservice (while still in a vacuum), add a little oil then do a performance test of the system to see if everything is working but it is a little hard to check all the specs in the cooler season like now.
Old Nov 5, 2006 | 05:35 AM
dawnriver's Avatar
Default Re: Check the pressure of the AC system? (Duane_in_Japan)
Thank you very much!
greenquark
Jul 15, 2016 03:54 PM
Tank_EM2
Honda Civic (2001 - 2005)
Jul 2, 2015 05:41 PM
greenteagod
20
May 8, 2014 08:25 PM
JJT211
Apr 8, 2013 09:11 PM
nixadm
Jul 5, 2004 08:59 PM
