Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Flywheel torque specs revisited
Old Nov 4, 2006 | 05:44 PM
newmaac's Avatar
Default Flywheel torque specs revisited
Hi folks, newby to your site. It looks great from what I have been able to see so far.
I did a search to find torque spec info for a 99 Civic. (D16Y7 1.6, 5 speed)
I found a member that previously asked for the clutch and flywheel specs, but neither he or the answerer mentioned year make and model.
The answer came back with 76 ft lbs on the flywheel and 19 ft lbs on the clutch.
Does this sound like the right specs for the 1.6?
Thanks in advance for your help.
If Murphy has anything to do with it, I will find my manual soon after I re-install the engine and transmission. )
Mike
Old Nov 4, 2006 | 06:08 PM
Miracle's Avatar
Default Re: Flywheel torque specs revisited (newmaac2000@yahoo.com)
Too bad you missed the right forum... this is for the 06+ Civics.
The forum you need is two above this one on the main page.
Old Nov 4, 2006 | 06:55 PM
TRE_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newmaac2000@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote"> 76 ft lbs on the flywheel and 19 ft lbs on the clutch.
Yes.
Jk_DC2
Feb 17, 2009 10:40 AM
nubs
Dec 14, 2004 10:22 AM
90accorddx
Sep 22, 2004 11:48 AM
AllMoToRB18c
Sep 23, 2003 10:00 PM
