swapping a prelude motor into a Ek ?????
Old Nov 4, 2006 | 03:52 PM
billy hoang's Avatar
Default swapping a prelude motor into a Ek ?????
i apologize if this bothers anyone but i was just hoping for a direct answer to my question .
i have a 1997 prelude that recently had the transmission go . so everything is perfect still and i would not like to replace the transmission .
So i was thinking about getting a EK hatch shell and doing a swap .
and my question is :
1) What parts from the prelude has to be switched over ?
2) is it a direct bolt on ?
3) if not , what needs to be done ?
4) can i use the stock EK transmission work with the prelude motor ?
thanks
-billy-
Old Nov 4, 2006 | 04:47 PM
turtleman321's Avatar
your gonna need aftermarket mounts, axles, and a bunch of other stuff. and you need a transmission from an h series motor.
Old Nov 4, 2006 | 04:48 PM
actually you could get the adapter plate to run h hseries engine and a d series trans
Old Nov 4, 2006 | 05:28 PM
Default Re: (turtleman321)
can i cut out the mounts from the prelude and weld it into the civic engine bay ? or is it much easier and less time consuming to buy the mounts ? and other parts you could tell me ?
or maybe is it better to sell the car ?
Old Nov 4, 2006 | 06:38 PM
i will let someone else answer everything else. but just read the stickys at the top. i know you can use the stock civic drivers side mount. i just replaced mine.
Old Nov 5, 2006 | 09:00 AM
hondaZvic's Avatar
Default Re: (billy hoang)
it is better to buy the mounts.
in ur case, if ur looking to save money, i would just replace the H tranny.
if not, u still have to get another B series tranny, and the H2b kit.. or whatever... then mounts, then axles, then wire it, then the ek shell....
and to put all this in the civic.....
click HERE
Kicknessell98
Aug 11, 2018 06:54 AM
PMautomotive
Jun 22, 2017 11:52 AM
popRAWvtec
Feb 6, 2007 01:25 PM
victoriasamantha
Mid-Atlantic (Sales)
Jan 27, 2006 08:30 PM
archmage
Sep 28, 2001 04:27 PM
