Wisconsin FS/FT/WTB November thread
Well another month closer to the snowy season, lets see what you guys have!!
aem tru power alt. pulley, blue. 10
y8 head. no valve cover, no intake mani, broke coolant temp sensor(easy to replace. 60 picked up and its yours.
I got stuff. Lets see if anyone wants it.
99-00 Si Hood, slighty dented- FREE to whoever wants to pick it up. It's blue with a charcoal grey center. Great if you have an 99-00 civic with a CF hood and want to take it off for winter. If you drive in winter. Uh, so, yeah.
99-00 Si springs - $40
B16 Intake tube - OEM - $15
B16 Intake Manifold - $50
B16 Fuel Rail - $30
B16 Injectors - $10ea. SOLD
B16 Fuel Regulator - $15
B16 Throttle Body - $25
B16 Intake Manifold Bracket - $10
B16 AC Bracket - $20
B16 Upper Exhaust manifold/w Heat Shield - $10
JDM ITR Pistons - .25 OS - $65
B18C5 Rods - make offer
B18C5 Crank- make offer
APR Head Bolts -make offer
BSeries Oil Pump - make offer
1 Set of B16A2 Intake Rocker Arms - $200 Excellent condition
1 Set of RM Gen2 Intake Dual Valve Springs and Ti Retainers. $50
1 B17 GSR Intake Cam. $10
H&R Street Performance Coilovers -EK/EJ8- $500 http://www.kingmotorsports.com...at=44
96-00 Trunk carpet and Fiberboard deck - $20
Exedy Stage 1 Pressure Plate - $25
PM me if you are interested in any parts. Thanx.
EDIT:
Modified by JDM_teh_WIN!! at 1:55 AM 11/6/2006
Modified by JDM_teh_WIN!! at 11:42 AM 11/7/2006
Modified by JDM_teh_WIN!! at 11:43 AM 11/7/2006
Modified by JDM_teh_WIN!! at 10:54 AM 11/8/2006
Modified by JDM_teh_WIN!! at 10:55 AM 11/8/2006
Modified by JDM_teh_WIN!! at 12:51 PM 11/22/2006
Modified by JDM_teh_WIN!! at 9:17 PM 11/26/2006
Modified by JDM_teh_WIN!! at 2:08 PM 12/1/2006
Modified by JDM_teh_WIN!! at 1:08 PM 1/9/2007
B16 Fuel Rail - $30
EDIT:
FS- UPDATED
TI-83plus graphing calcutor, perfect working condition-$25!
88-91 Crx rear bumper, no cracks etc. Has metal plate since the exhaust came off on the right, but you can cover it with a rear lip or something
-$25
Str dipstick for 99-00 si's-$10
B-series starter-$35 picked up
obd0-obd1 B-series alternator-$35 picked up
Both in perfect working condition.
obd1-obd2 ignition coil-$15
obd1-obd2 ignitors-$5 each
Obd0 Ls pr4 ecu, unchipped and for manual transmission-$30
big yellow wastegate spring for tial 44mm wastegate (7 psi)-$15
92-95 Civic HB door panels-$15 for both picked up! ...they are a dark navy color
90-91 Crx SI brake lines (front+rear)-$10 includes harware to install. Great for Ef guys that are doing rear disc brake conversions.
88-91 Civic/Crx compensator arms-$10
Gas pedal from 91 Crx si (will work on all 88-91 Civic/Crx's)-$10
Arp head studs for GSR, ls-vtec, and b20vtec engine's. Complete set w/ washers. On the top of (2) nuts it's starting to strip since you're supposted to use a deep socket to take them off. You can use these and they will torque perfectly fine. $50
Steering column w/ tilt option for 88-91 Civic/Crx-$30
P72 stock rods $10
JDM b20b AC compressor. Came off of Osaka Jdm motor 30k miles. MINT!! I believe this works with LS integra's as well-$20
95 Gsr power steering pump-$20
95 Gsr power steering pump brackets-$15
95 Gsr alternator brackets (top+bottom)-$10
95 Gsr Honda water pump-$15
95 Gsr Honda timing belt, like new only 10k miles on it-$10
95 Gsr upper/lower alternator brackets-$15
95 Gsr power steering brackets (have an extra 2 but they are just the lower ones)-$5 each
95 Gsr cam gears-$10
92-95 Civic front strut forks-$10
92-95 Civic steering column yoke-$1
94+ Integra drivers side motor mount bracket-$10
90-93 Integra front wheel hubs-$15
88-91 Civic/Crx coin tray-$5
88-91 Civic/Crx radiator T bracket-$10
88-91 Civic Center air vent-$5
88-91 Civic/Crx windshield washer reservoir-$5
88-91 Civic/Crx windshield Cowl-$5
88-91 Civic/Crx windshield wiper arms-$10
88-91 Civic/Crx hood latch-$5
88-91 Civic/Crx tekniq steering wheel hub for sparco steering wheels-$30
88-91 Civic/Crx hood popper-$2
88-91 Civic/Crx power mirror switch (not power folding mirrors)-$2
B18b cams-$20 for both
88-91 Civic/Crx Steering wheel hub for use w/ momo+sparco steering wheels. Brand is Tekniq high quality made in Italy-$30
I believe this is a 92-95 Civic power steering rack+pinion-$20! Price LOWERED!! $10 please come pick this up!
Cam gears for all b-series. Originally off Ctr cams. -$15 Lowered price $10
88-91 Civic/Crx rear upper control arms. Great condition, no rust. bushing in great condition-$15 for both sides Price LOWERED $10
92-95 Civic Tenzo-r seat bracket w/ sliders for drivers side- $30 Included is another one i made, doesn't look as good, but still functions perfectly fine.
obx pedal pads, missing 2 nuts and 1 clamp which you can get at a hardware store-$2
Msd blaster 2 coil-$25
Stock valves from 99-00 B16 head. $15 for all 16!!
Msd cap for use w/ external coil for ALL 88-91 ALL Civic/Crx/Integra's-$20
88-91 Civic/Crx fan
94+teg fan
90-93 Teg fan
10" slim fan
92-00 Civic fan
$20 Each! Lowered price $15 each
Windows-
90-91 Civic Hb- Passenger's door window and passenger's quarter panel
89-91 Crx-Driver's door window *not pictured*
$35 each!
SOON FOR SALE....
RHD Crx rolling shell-pm me
Custom made b-series ramhorn manifold
'97 Type r tranny fully rebuilt by gearspeed! carbon coated synchros, new sleeve sets, new bearings etc.
Anyone interested in any parts PM me
Modified by theinfamouskonrad at 2:34 PM 11/12/2006
-$25
P72 stock rods $10
88-91 Civic/Crx fan
94+teg fan
90-93 Teg fan
10" slim fan
92-00 Civic fan
Windows-
$35 each!
SOON FOR SALE....
d16a1 (86-87 integra) complete swap slightly dissassembled $100 new headgasket was told it runs good
Ys1 Non LSD LS tranny $250 comes with:
90-93 DA rear engine bracket
b-series starter
96-00 Civic Ex tranny bad input bearing and bad 2nd gear $30
b-series alternator brackets upper and lower $20
b and d series Electric Vehicl Speed Sensors (VSS) $25)
94-01 Integra GSR guage clusters (3 of them 1 is missing all the bulbs though) they should all be 94-99 $50 each $30 for the one with no lights
These are needed for swap in 88-91 Civic/Crxs:
AZ racing mounts and 90-93 shortened Teg shift linkage with short shifter $230
2.25 - 1 3/4 test pipe (the b-series exhaust is slightly longer then d-series) $20
2.5 - 1 3/4 test FLEX pipe (also on this one it can only be used on a 2.5 collector) $35
-Shane
Iuse2brk@yahoo.com
612-229-8103
If you do group buys I'll knock money off!!
Modified by vtecn8ive at 6:22 PM 11/10/2006
b-series starter
-Shane
Iuse2brk@yahoo.com
612-229-8103
WTB: Honda D16Z6 flywheel inspection cover. D16Z6 engine to transmisson braces.
For Sale: 240SX project car. I thinking about $1000?
http://hondamarketplace.com/zerothread?id=1796563
I was putting together a 88 Crx with d15z1 swap but its to damn cold and i don't have time for it any more.
All that really needs to be done is put the interior back together (which i should have most pieces)
Things that were just done:
Converted to obd1
New rear shoes
Rotors were turned at that time
New rear left wheel cylinder
Front brakes have a little bit of meat left on them but have been sitting for awhile
New distributor cap
New rotor
New oil pan gasket
Newer o2 sensor (this is the 5wire)
Crx Si front bumper with lip
Interior is somewhat black (black carpet, dash, si door panels)
I have the rear interior panels but I dont think they will work since they are from 90-91 Crx Si (different seat belt positions) but can include)
Things it will need:
1. underdash harness (the one thats in it works but i had 94 Integra dash in it before hand and cut the wiring up to work with it) so the guage cluster works though.
2. Connect coolant lines to the heater hose (i'm bypassing it right now cuz when i installed the motor i didn't have a heater core in the car.
3. Front right wheel bearing (i think)
4. Figure out why its smoking (it could be the headgasket but I"m not positive, could also be something simple)
5. May need tires I gotta see if i have good ones to put on.
6. Needs new front springs
7. Passenger Side door needs to be leveled out
HOODS NOT CLOSED:
A little messy:
Car can be driven home. You just will be missing a dash. Seat belt is hooked up though. Steering wheel and light switch will be put back on.
As you can tell the car has issues but it should be one hell of a gas saver when you get it going and on the road.
-Shane
Iuse2brk@yahoo.com
612-229-8103
Converted to obd1
New rear shoes
New distributor cap
New rotor
New oil pan gasket
HOODS NOT CLOSED:
A little messy:
-Shane
Iuse2brk@yahoo.com
612-229-8103
Big garage sale!
EX trans, snow tires, DOHC VTEC distributor, etc...
http://hondamarketplace.com/zerothread/1808459
WTB For the Del Sol:
Black Hood in good condition (i could trade my partially beaten up one if you need one)
Black rear bumper
I'm not sure what its called but its on the trunk around where the Key is by the trunk (in between the tail lights)
-Shane
Iuse2brk@yahoo.com
612-229-8103
Black rear bumper
-Shane
Iuse2brk@yahoo.com
612-229-8103
Here are some of the turbo parts that I am selling. It came off of my Integra. Everything is bolt ons. All of the parts are still in good shape. The turbo setup has around 600 miles on it.
Precision SC6031 Turbo w/upgraded S-housing
Precision 600 hp Intercooler
Precision 880cc Injectors
Tial 44mm Wastegate
NSR Top Mount Turbo Manifold
NSR 3 inch Downpipe
Custom 2.5 inch Intercooler Pipings
Cusco Oil Catch Can
Greddy Type R BOV
Blox Boost/Oil Pressure Gauges
SS Braided Oil Lines
Taking Reasonable Offers
Email: skellatorthao@yahoo.com
Located in Wisconsin
Tial 44mm Wastegate
NSR 3 inch Downpipe
Cusco Oil Catch Can
Greddy Type R BOV
WTB a built GSR block or full motor, sleeved is a requirement.
hit me up on aim or e-mail
rtnlsltn or wasobi33@new.rr.com
thanks,
justin
thanks,
justin
P2E- $30
P2P- $30
PM5- $20
some gay tach- free
avid H/F billet mounts- $100
H/F swap axles (90-93 axles w/ prelude inner shaft)- $40
H/F civic swap harness- $50
H/F shifter and cables- $40
stock hatch rear window- $20
B-series shifter linkage- $25
OBD0 B-series dizzy- $30
B16 flywheel(resurfaced)- $30
B18 crankpully- $10
civic suspension- $20
JDM b16 oil cooler- $20
Type-r clutch and pressure plate- $30
resistor box w/ harness- $10
OBD0 b-series harness- $30
Stock civic corners and inner tails (92-95)- $20
2 gadge pods- $10
F22 intake manifold & throttle body- $20
D16a6 intake manifold- $10
integra front brakes- $30
integra 90-93 intermedate shaft- $30
Autoloc KL600 keyless entry- $30
(92-95) steering colum with key- $20
Make offers on any thing
youneedparts@hotmail.com
or IM me
thanks
P2P- $30
PM5- $20
some gay tach- free
B18 crankpully- $10
2 gadge pods- $10
or IM me
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_y8 »</TD></TR><TR><TD CLASS="quote">Hope everyone enjoys thanksgiving!
2 paid days off work + buying big screen TV on Friday = enjoyment!
</TD></TR></TABLE>2 paid days off work + buying big screen TV on Friday = enjoyment!
