Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
TOYOTA TECH HAS IMPORTANT QUESTION ABOUT CR-V...
Old Nov 4, 2006 | 03:40 PM
laford1986's Avatar
Default TOYOTA TECH HAS IMPORTANT QUESTION ABOUT CR-V...
Hey, I have a 1997 CR-V automatic. I am having a problem with the transmission. The LOCK-UP in overdrive is not engaging normally. It seems to lock up when cold, but when trans reaches operating temperature, it won't lock the converter. I service the transmission regularly. Drain, fill, drive, drain, fill, etc. I DO use HONDA ATF-Z1. The car has 123,000 miles. ANY HELP WOULD BE GREATLY APPRECIATED
Old Nov 6, 2006 | 05:22 AM
Ross 2.0's Avatar
In a Junkyard near you.
there is no overdrive in a honda transmission.
I would suggest going through the shift solenoids and checking/ cleaning them then see if the condition resolves itself.
Also check out both ECT's to make sure they are ok.
If you need more help just ask
Old Nov 6, 2006 | 05:44 AM
DaiJekBok's Avatar
Default Re: (Ross 4107)
Are you out of your mind? Overdrive is any gear that's taller than 1:1... I'm sure they exist, but I've never seen a Honda transmission that doesn't have one (or two) overdriven gears.
Old Nov 6, 2006 | 01:59 PM
Ross 2.0's Avatar
No honda has overdrive. Look at any honda gear shifter and tell me.
It's just the terms honda uses wether it's an overdriven gear or not. Don't get caught up on the details.
Old Nov 7, 2006 | 05:21 AM
DaiJekBok's Avatar
If it doesn't have an overdrive button on the shifter then the transmission doesn't have overdrive? They all have overdrive whether they have a button or not -- there's no button for VTEC either, but my Ridgeline has it (along with two overdrive gears). Overdrive is not "just a term Honda uses" either.
Also, FWIW, my mom's 1999 CR-V did, in fact, have an overdrive toggle button at the end of the shift lever. However, I'll let you in on a little secret: ever wonder why there's a D3 position on Honda's auto trannies? BINGO -- they lock you out of overdrive gears -- same as a toggle button would do.
I think it'd be wise to research your information ittle further before passing it on to others. Saying "No Honda has overdrive" is simply false.
Old Nov 7, 2006 | 08:52 AM
Mr.E.G.'s Avatar
Default Re: (DaiJekBok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaiJekBok &raquo;</TD></TR><TR><TD CLASS="quote">If it doesn't have an overdrive button on the shifter then the transmission doesn't have overdrive? They all have overdrive whether they have a button or not -- there's no button for VTEC either, but my Ridgeline has it (along with two overdrive gears). Overdrive is not "just a term Honda uses" either.
I think it'd be wise to research your information ittle further before passing it on to others. Saying "No Honda has overdrive" is simply false.</TD></TR></TABLE>
BINGO
Old Nov 7, 2006 | 11:42 AM
cnyej1's Avatar
Default Re: (Mr.E.G.)
The GF's 05 CRV has an OD button on the shifter.
Richardgede
Honda CR-V & Element
Mar 27, 2019 09:26 AM
curthyranks
May 9, 2017 04:43 AM
new-world
May 6, 2013 04:49 PM
burog
Transmission & Drivetrain
Jan 11, 2009 07:15 PM
