Need Help with AC clutch issue
Old Nov 4, 2006 | 02:21 PM
bodean's Avatar
Default Need Help with AC clutch issue
I bought a 1995 Civic DX with a bad ac clutch. I replaced the clutch, evac the system and then recharged. The AC clutch wont come on. I unplugged the condenser fan relay and the clutch kicked in, but then of course my high side pressure shot up because the fan was off. Plugged the fan back in and no clutch WTF????
I figured out the AC relay is not getting the ground from the ecm (black wire with red stripe A15 in connector) unless the condenser fan relay gets unplugged. Crazy ground loop going on. Any ideas?? I am going nuts on this one. Any help would be great, Thankx in advance.
Old Nov 5, 2006 | 04:40 AM
bodean's Avatar
Default Re: Need Help with AC clutch issue (bodean)
bump
Old Nov 5, 2006 | 05:44 AM
nsxmatt's Avatar
Did you check the relay to see if it was good?
alextech
Honda Civic (2006 - 2015)
Mar 27, 2018 10:30 PM
BSDMotorSports
Jul 28, 2013 04:12 PM
Mackln308
Jul 30, 2010 11:34 AM
freestyler_
32
Jul 3, 2009 09:23 AM
sk8er602
May 22, 2007 07:25 PM
