HELP!!!!!clutch fluid problem!!!
Old Nov 4, 2006 | 09:41 AM
BiGcAmBoDiAnSaUsAgE's Avatar
Default HELP!!!!!clutch fluid problem!!!
i juss bleeded my clutch and when i got somebody to pump the clutch 3 time and tightin it all the way till i see the bubble i put more fluid in there and how do i know its finish... when i was done, when i step on the clutch it takes a while for it to come back up... then when i shift it over rev cuz the clutch...
Old Nov 4, 2006 | 09:50 AM
SP GARAGE's Avatar
Default Re: HELP!!!!!clutch fluid problem!!! (BiGcAmBoDiAnSaUsAgE)
keep on pumping that clutch till it feels normal. then bleed it. it will take a while till you build pressure
Old Nov 4, 2006 | 09:56 AM
Mr Hammond's Avatar
a/k/a Jomo
How many times did you bleed it? I just replaced my soft line and I probably gravity bled it a good dozen times before it felt perfect.
Old Nov 4, 2006 | 02:32 PM
Default Re: HELP!!!!!clutch fluid problem!!! (Mr Hammond)
like 4-5 times... it still feel the same like it get stuck and pops back up... i thought i fucked it up... hope not!!!
Old Nov 4, 2006 | 02:48 PM
crimsonv4mpire's Avatar
i always run a whole bottle through, get it all nice and clean *
Old Nov 5, 2006 | 08:08 AM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiGcAmBoDiAnSaUsAgE &raquo;</TD></TR><TR><TD CLASS="quote">like 4-5 times... it still feel the same like it get stuck and pops back up... i thought i fucked it up... hope not!!! </TD></TR></TABLE>
You're not done yet.
Old Nov 5, 2006 | 08:09 AM
slambedcivic's Avatar
clutch slave or master cylinder could also be bad since its not coming back up.
Flux
Jan 17, 2012 03:32 PM
lisajasmin
Jun 4, 2008 04:56 PM
plusONE jboy
Apr 23, 2004 04:42 PM
C-Zero
23
Feb 28, 2004 05:56 PM
monsterb18b
Nov 20, 2003 09:45 AM
