correcting camber with a sledgehammer
Old Nov 4, 2006 | 08:55 AM
XDEep's Avatar
Default correcting camber with a sledgehammer
i got -0.8 camber on my driver's side, i suspect due to an accident i had a while back. he didn't even hit my fender, but hit and tore off my front bumper. so i guess it managed to nudge the wheel well enough to throw off the camber. the toe is off a little too..
anywho, it's a completely stock car and i don't want to fork out for a camber kit, especially since i'll only use one side. so, i'm just going to take a sledgehammer and whack the wheel well. i'll use some kind of plate or something to distribute the force.
i'll try to update with statistics on whack force vs. camber adjustment values.
Old Nov 4, 2006 | 09:02 AM
jdm_bones's Avatar
Default Re: correcting camber with a sledgehammer (XDEep)
WTF! are you serious....hahahahahaha! please take pictures I want to see the out come of this.....hahahahha! LOL...be careful now, don't fudge anything else up!
Old Nov 4, 2006 | 09:03 AM
jdm_bones's Avatar
Default Re: correcting camber with a sledgehammer (jdm_bones)
Requesting before and after pictures
Old Nov 4, 2006 | 09:05 AM
SlammedDC2's Avatar
Semper Fidelis
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote">Requesting before and after pictures </TD></TR></TABLE>
X2
Old Nov 4, 2006 | 09:08 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XDEep &raquo;</TD></TR><TR><TD CLASS="quote">i got -0.8 camber on my driver's side</TD></TR></TABLE>
That's within spec. I suggest you leave it alone rather than hitting things with a sledgehammer.
Old Nov 4, 2006 | 11:56 AM
dragon909boi's Avatar
.8 aint that bad...
Old Nov 4, 2006 | 12:12 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: (dragon909boi)
beat it up boy
Old Nov 4, 2006 | 01:12 PM
53JDMDC2's Avatar
holy crap you cant be serious you can probobly leave it alone it is within spec. If your tires are wering even leave it alone. If not buy a cheap camber kit off e-bay. Thats what i bid and it works great.
Old Nov 4, 2006 | 01:29 PM
Leo C's Avatar
Night Owl
Default Re: correcting camber with a sledgehammer (53JDMDC2)
It sounds like you have a damaged suspension component. DO NOT TAKE A SLEDGEHAMMER TO YOUR CAR!!
Old Nov 4, 2006 | 01:42 PM
Padawan's Avatar
Darth ModerVader
Default Re: correcting camber with a sledgehammer (Leo.C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leo.C &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like you have a damaged suspension component.</TD></TR></TABLE>
How does camber that is within factory specs indicate a damaged suspension component?
Old Nov 4, 2006 | 02:13 PM
juda7's Avatar
Beating your car with a sledge doesn't seem like a good idea, BUT do it any way.
Pics please
Old Nov 4, 2006 | 06:33 PM
Dogginator's Avatar
Daisy... Daisy...
Old Nov 4, 2006 | 07:19 PM
845_dapek's Avatar
Default Re: correcting camber with a sledgehammer (Dogginator)
[<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote">Requesting before and after pictures </TD></TR></TABLE>
x3
Old Nov 4, 2006 | 07:49 PM
Leo C's Avatar
Night Owl
Default Re: correcting camber with a sledgehammer (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
How does camber that is within factory specs indicate a damaged suspension component? </TD></TR></TABLE>
.8 on one side, and I'm assuming 0 on the other side, would seem to indicate a problem.
Old Nov 4, 2006 | 07:58 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leo.C &raquo;</TD></TR><TR><TD CLASS="quote">.8 on one side, and I'm assuming 0 on the other side, would seem to indicate a problem. </TD></TR></TABLE>
Why would you assume 0 degrees on the other side?
Old Nov 4, 2006 | 08:03 PM
Leo C's Avatar
Night Owl
Why would you assume 0 degrees on the other side? </TD></TR></TABLE>
Since he seemed to indicate an accident and a exessive camber/toe on that side, I naturally assumed that to be the case. I could very well be wrong. Not trying to argue, your knowledge of Hondas/Acuras probably would shame mine
Old Nov 4, 2006 | 08:11 PM
Padawan's Avatar
Darth ModerVader
Well, his post is rather vague, and it certainly would have been more helpful if he'd provided all of the values. I'm also curious how the values were determined, and why the toe wasn't corrected if it was found to be "off" while it was on the alignment rack. As for the camber, I'd be surprised if the opposite side wasn't within a 1/2 degree or so +/-, which really wouldn't be cause for concern. I suppose we'll need to wait for the original poster to elaborate a bit before being able to provide any other suggestions (assuming he hasn't already carried out the ridiculous sledgehammer idea).
Old Nov 4, 2006 | 08:31 PM
NrG's Avatar
NrG
Padawan is right on the money.
every car has neg camber degree. each cars have their own specs and there's only enough you can adjust with oem arms. with a camber kit, it gives you more room to adjust.
Cars shouldn't be at 0 degree camber, unless your wheels are made out of concrete. I'm not even sure how you came up with that number.
suspension specs always changes from the type of wheels and tires you use.
There are tons of ways to adjust your camber without a sledgehammer. Like Padawan said, if you found out what camber you had, then you were probably on top of a alignment rack. That also means, you were able to make adjustments.
Leo.C, no one mention anything about toe.
Old Nov 4, 2006 | 08:43 PM
aaronISthrowed's Avatar
Default Re: (NrG)
In for pix, even though i would never hit my car with a sledgehammer.
Old Nov 4, 2006 | 08:52 PM
Yambor's Avatar
L M F A O
Old Nov 5, 2006 | 02:02 PM
vladd's Avatar
both sides should be negative from the factory.
regardless, pics of the carnage would still be fun
Old Nov 5, 2006 | 06:53 PM
Default Re: correcting camber with a sledgehammer (civicdxtyper)
So hit your car with a hammer yet?
th34nt0ni0
Suspension & Brakes
Dec 21, 2008 02:15 PM
XDEep
Suspension & Brakes
Nov 5, 2006 07:42 PM
Kyles ej1
26
Nov 19, 2004 06:09 AM
92siracer
Feb 19, 2004 09:25 PM
Vtecfool
Jul 31, 2003 11:55 AM
