removing insterment panel cover
i'm looking for some help removing the dash unit around the spedo and that area behind the steering wheel.
has anyone else done this? i'm assuming it's just a bunch of clips holding it all on.
Thanks
Thanks
no one has done this yet?? or knows of any good links for "how-to".
i've looked for "how-to" directions but all i can find is the picture of all the parts, not really showing you what to take off and what not....there's like 100 parts in the picture..
any help would be appreciated. i need to replace the interconnect RCAs from the back of my deck to my amp...
not sure if they do or do not have anything but http://www.collegehillshonda.com had the how to on how install springs and exhaust, might have what u are looking for.
i have to remove the interment panel, then remove the center piece around my deck (i've had the stock deck replaced), then pull out my deck and replace the interconnect rca cables
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mooseheads36 »</TD></TR><TR><TD CLASS="quote">i have to remove the interment panel, then remove the center piece around my deck (i've had the stock deck replaced), then pull out my deck and replace the interconnect rca cables
thanks</TD></TR></TABLE>
everything basically pulls apart. there is 1 plastic screw under the kick panel, and 2 8mm bolts hold the radio in, otherwise you just yank it all apart
Tampa75
Audio / Security / Video
Oct 14, 2018 06:02 AM
