terminal exponder doradiator
umm, what is that?
Anway could be your seals or gasket (oil pan) look on the drivers where your timing belt cover is thats where your seals are located (cam seal, oil pump seal, crank seal) i were you i'd wash the engine with hot soapy water then get a die and spray it or however they do it. To make things easy on you take to a shop and have them look
good luck
good luck
1) STFU, you clearly have no clue what you're talking about.
2) Hit reply... don't make a new thread.
3) The OP should Search.... I think this has been covered atleast 2-3 times within the last couple months.
Kyle700
Jan 18, 2015 04:57 PM
immalooser
May 17, 2006 03:27 PM
