HELP OIL LEAK!!!!!!!!!!!!!!!!!!!!!
Old Nov 3, 2006 | 10:03 PM
Stevegunit16's Avatar
Default HELP OIL LEAK!!!!!!!!!!!!!!!!!!!!!
OK I bought a 1995 honda accord coupe LX and its leaking oil I tried to see where from but it s just all over the place buts most of it is around the oil pan close to the driver side wheel... If its not my Oil pan gasket what else can I be leaking from????????????????
Old Nov 3, 2006 | 10:24 PM
lunarone's Avatar
Default Re: HELP OIL LEAK!!!!!!!!!!!!!!!!!!!!! (Stevegunit16)
it might not be oil, it might be dorad fluid leaking from your terminal exponder doradiator, which is just as bad of a case as it sounds...
Old Nov 4, 2006 | 06:24 AM
Honda-Master's Avatar
possibly from the balancer shaft seal........94-97 accords had a real issue with those seal leaking and in some occasions totally popping out ...
if it is that seal, when replacing it, make sure to install a retainer as well , dealer sells them 4-5 dollars
Old Nov 4, 2006 | 10:29 AM
standbackimapro's Avatar
Timing Belt cover seal
Old Nov 4, 2006 | 08:02 PM
s2k24's Avatar
sound like seals behind the timing belt are leaking. possible crank,balancer seal, oil pump seal,cam seal leak. you need to take off the upper and lower timing belt covers to see which seal or seals are leaking. you mine as well do a timing belt,water pump and drive belt replacement while you have everything off. get the factory balancer seal retainter if balancer seal is leaking
Old Nov 5, 2006 | 02:45 AM
Duane_in_Japan's Avatar
Default Re: HELP OIL LEAK!!!!!!!!!!!!!!!!!!!!! (s2k24)
You ned to get a couple cans of GUNK degreaser, spray everything down, let it sit a little while and wash it all off, reinspect for missed areas, hit it again. Go for a test drive and reinspect for fresh oil leaks, then let us know where its coming from for sure.
Do not wash your engine in your moms yard or she will surely beat your ***.
ryaldin
Jan 26, 2015 11:39 PM
caliskier
Mar 22, 2012 06:27 PM
Josueneta
May 7, 2010 01:43 PM
gnccracer20
11
Feb 4, 2009 03:14 AM
