Suspension & Brakes Theory, alignment, spring rates....
Problems with ETD Crossmembers?
Old Nov 3, 2006 | 06:53 PM
BIGTUNA's Avatar
Default Problems with ETD Crossmembers?
Hey, has anyone had any problem with ETD crossmembers on EF's or any other chasis? Tonight at the track at about the 1000' my ETD crossmember snapped the right radius rod nearly causing me to pinstripe my CRX on the jersey wall. After I limped the car back to my pit and removed the hood I was shocked to see that my right radius rod had snapped where the threads end on bar and the left bar was bent really bad at the same spot. I am very careful strapping the car down and I never put any straps on the crossmembers I only use the tow hooks. The crossmember might have 20 passes on it, my car is a track only car and launched on slicks, they say the stuff is "race proven"
Has anyone else had a similar problem or other problems with ETD traction bar/ crossmembers. If so how was ETD customer service?
In the morning I will post up some pics.
JDM_home
Apr 9, 2015 07:09 PM
KevinEF7
Nov 9, 2012 05:38 PM
CRX 2.0V-T
Jan 7, 2007 07:40 PM
Running925
Dec 25, 2006 12:10 AM
Buttcrack
Jan 29, 2004 06:25 AM
