Guage Cluster lights work sometimes... new bulbs?
Old Nov 3, 2006 | 10:34 AM
Tonyl507's Avatar
Default Guage Cluster lights work sometimes... new bulbs?
My gauge cluster lights work fine most of the time, but a few weeks ago ONLY one side of the cluster went out. The fuel gauge and a little bit of the speedo are dark, but teh left side is still lit and works fine. I can dim them and make em brighter no problem.
Anyway this happend a few weeks ago, then one night it worked again for about a week. Now the same side is dark again.
Are there bulbs behind the cluster? how do you change them? and why would it work, then not work, then work again, then not work again....maybe its not the bulb? anyone ever had this problem?
Old Nov 3, 2006 | 10:40 AM
93Ls-tegra's Avatar
Default Re: Guage Cluster lights work sometimes... new bulbs? (Tonyl507)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tonyl507 &raquo;</TD></TR><TR><TD CLASS="quote">My gauge cluster lights work fine most of the time, but a few weeks ago ONLY one side of the cluster went out. The fuel gauge and a little bit of the speedo are dark, but teh left side is still lit and works fine. I can dim them and make em brighter no problem.
Are there bulbs behind the cluster? how do you change them? and why would it work, then not work, then work again, then not work again....maybe its not the bulb? anyone ever had this problem?</TD></TR></TABLE> the same thing happend to mine it went on and off on and off sucks at night time......anyways im gettin it fixed saturday i dont remember the part but ill message later ok ill ask again.i tried hittin it lightly then it just turned off complety so dont hit it just some advice.
Old Nov 4, 2006 | 02:00 PM
Tonyl507's Avatar
Default Re: Guage Cluster lights work sometimes... new bulbs? (93Ls-tegra)
bump, anyone ever have this problem?
Old Nov 4, 2006 | 05:25 PM
EK FLY's Avatar
replace your dimer
Old Nov 4, 2006 | 05:28 PM
PhatTeg86's Avatar
Default Re: Guage Cluster lights work sometimes... new bulbs? (super-hatch)
i just did mines you have 3 leds behind the cluster the cost about 60c each plus resistors at 40c each very simple swap took me 10 min
as soon as you take your cluster off you will see the leds i am talking about
Old Nov 4, 2006 | 05:34 PM
vinai's Avatar
Wouldn't be the dimmer the dimmer is placed in series with the lights while the lights are in parallel. Most likely you have a bad bulb. I would just replace the bulb or bulbs. They usually come in a set of two. If you don't think it is the bulb for some reason you can just buy a set of bulbs don't open the box and just move the known good bulb to the side that isn't working check to see if it lights up and if it it does problem solved, and you have the bulbs right there.
Old Nov 5, 2006 | 10:47 AM
Tonyl507's Avatar
Default Re: Guage Cluster lights work sometimes... new bulbs? (vinai)
nice, thanks ill try it, anyone knoe the size bulb i need?
Old Nov 5, 2006 | 01:06 PM
S1NFUL RL1 619's Avatar
those bulbs are 194 or 168 ... i just installed some amber 194 for my guage cluster. i had the red ones in there, but looked pinkish. amber looks dope!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tonyl507 &raquo;</TD></TR><TR><TD CLASS="quote">My gauge cluster lights work fine most of the time, but a few weeks ago ONLY one side of the cluster went out. The fuel gauge and a little bit of the speedo are dark, but teh left side is still lit and works fine. I can dim them and make em brighter no problem.
my guess is bad bulbs.. .if not that, then faulty wiring.
to get behind the guage cluster... unscrew the two screws on the upper part of the guage housing, remove housing
undo the 3 screws that hold the cluster in place... now you don't necessarily need to unplug the harnesses, but you can just twist the cluster around so you can see where the 194/168 bulbs go.
B_Swapped93
Jul 18, 2013 03:56 AM
spoolin_teg
Dec 17, 2007 04:40 PM
vtec.dc2
May 22, 2006 12:36 PM
ali7up
Feb 24, 2006 05:48 AM
crexer
Apr 4, 2004 08:29 AM
