dc2 Idles high then idles low
I have 99 gsr, my check engine light threw code p1457, which is that evap crap. However my car during start up warms up at 2000rpm and after warmup chills at 1500. After a little bit of driving i turn off my car, then turn it back on and the car now idles at 500rpm. I cleaned the IACV, but that doesnt seem to be the problem. Wat do u think?
timing off? dizzy getting messed up? my car use to idle like **** threw code #9 (cylinder sensor) which is crank sensor inside the dizzy so i had to replace the whole unit. my idle would drop high/low and my timing was perfect....well mine was obd1 so codes are different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 »</TD></TR><TR><TD CLASS="quote">could be your fitv </TD></TR></TABLE>
What FITV is that? Only 94-95s have the FITV
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek »</TD></TR><TR><TD CLASS="quote">maybe your vacuum line is leaking?</TD></TR></TABLE>
That's what I was thinking!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ck123 »</TD></TR><TR><TD CLASS="quote">maf sensor?</TD></TR></TABLE>
wouldnt the maf sensor be detected by 0bd2???
it idles 250 rpm less. I cleaned the iacv already, instead of warming up at 2k rpm it warmed up at 1750 and then dropped to 1200 rpm after it was warmed up. Then i shut off the car turned back on and it idles super low, @ like 550-600 rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAmodified »</TD></TR><TR><TD CLASS="quote">it idles 250 rpm less. I cleaned the iacv already, instead of warming up at 2k rpm it warmed up at 1750 and then dropped to 1200 rpm after it was warmed up. Then i shut off the car turned back on and it idles super low, @ like 550-600 rpm.
If you unplug the IACV, it shouldnt idle up at all.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">
If you unplug the IACV, it shouldnt idle up at all.....</TD></TR></TABLE>
i know that
i know that
reed857
29
Jul 26, 2009 10:57 AM
russian_racer
Jun 28, 2003 02:01 PM
