weird temp readings =-(
Old Nov 3, 2006 | 05:48 AM
junior40er's Avatar
Default weird temp readings =-(
The temp gauge on my crx is acting weird. It will be normal but after a while temp will jump from the middle straight to the top, back to bottom etc. I know the engine itself is not getting too hot. Anyone has any idea why its doing this?? Thanks.
Old Nov 3, 2006 | 07:30 AM
v.i.massive's Avatar
Default Re: weird temp readings =-( (junior40er)
you need to check couple of things,check
ALL hoses make sure fluid is flowing all around
check you fan it come when it suppose to
bleed radiator
check termostat
and lastly check head gasket and water pump
Old Nov 3, 2006 | 07:34 AM
Coltmorris's Avatar
Default Re: weird temp readings =-( (v.i.massive)
Bad sender?
Old Nov 3, 2006 | 07:40 AM
randY49's Avatar
Default Re: weird temp readings =-( (Coltmorris)
I had this problem and posted it on a different forum.
The response I got was to change the "Thermo Unit". I haven't done this yet, i just unplugged the sender so that the gauge doesn't get jacked up. As soon as I get a chance to run to the parts store I'll get it fixed. Part costs about $25 and takes two minutes to change out. (or so I'm told)
Old Nov 3, 2006 | 09:34 AM
junior40er's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coltmorris &raquo;</TD></TR><TR><TD CLASS="quote">Bad sender?</TD></TR></TABLE>
where is that loca<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coltmorris &raquo;</TD></TR><TR><TD CLASS="quote">Bad sender?</TD></TR></TABLE>ed??
Old Nov 3, 2006 | 10:05 AM
JakeSpec420's Avatar
Bad seding unit on the side of the head use a 12mm deep socket to change it
Old Nov 3, 2006 | 11:33 AM
junior40er's Avatar
Default Re: weird temp readings =-( (JakeSpec420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeSpec420 &raquo;</TD></TR><TR><TD CLASS="quote">Bad seding unit on the side of the head use a 12mm deep socket to change it </TD></TR></TABLE>
on the left side or right side? under dizzy??
Old Nov 4, 2006 | 12:53 AM
yup sometimes the single snapon plug gets messed up too try changing that as well
GiceMob
Mar 26, 2007 09:06 PM
B6teen
10
Dec 23, 2006 05:55 PM
ablack934doorcivic
Oct 13, 2006 04:43 PM
camo_crx
Sep 1, 2006 02:08 PM
lude1888
Mar 3, 2006 08:42 PM
