common distributor parts
Old Nov 3, 2006 | 04:12 AM
ED8DX's Avatar
Default common distributor parts
If any one can help, what are the most common parts inside the distributor that are commonly changed or commonly go bad aside from the cap and rotor. This is for a '96 gsr, I am trying to help a friend narrow down why his car won't spark.
Thanks ALL.
Old Nov 3, 2006 | 06:42 AM
95 integra's Avatar
Default Re: common distributor parts (ED8DX)
Crank position sensor.....you'd get a check engine light for that though. Generally people just replace the entire distributor since they are fairly cheap for a new one. Could be a wiring problem as well, so if you have another friend w/ an integra, test their distributor before buying one.
Old Nov 3, 2006 | 11:34 PM
Fat Chick Magnet's Avatar
crank sensor.
Old Nov 4, 2006 | 02:59 AM
qfast817's Avatar
Default Re: (dc2rtek)
probly coil test it with a ohm meter
Old Nov 4, 2006 | 06:09 AM
HoUTX98GSR's Avatar
Default Re: common distributor parts (95 integra)
umm.. i think on obd2 cars the crank sensor is by the crank... anyways the most common thing to go bad inside the dizzy (in my experience) is the ignitor. Ive had 3 of them go bad in the 5 integras ive owned. Definately check the ignitor.
Old Nov 4, 2006 | 06:50 AM
95 integra's Avatar
Default Re: common distributor parts (HoUTX98GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoUTX98GSR &raquo;</TD></TR><TR><TD CLASS="quote">umm.. i think on obd2 cars the crank sensor is by the crank... anyways the most common thing to go bad inside the dizzy (in my experience) is the ignitor. Ive had 3 of them go bad in the 5 integras ive owned. Definately check the ignitor.</TD></TR></TABLE>
I believe the 96+ models have 2 crank position sensors....one on the crank and one in the dizzy.
accordlxr
Oct 3, 2007 07:06 PM
520_Motorsports
Feb 23, 2006 09:33 PM
fox23
Jul 25, 2005 03:56 AM
SI_niki
Jun 15, 2004 07:54 AM
