heater & a/c issue
my heat seems to stay hot constantly even if i dial down the temperature to the coldest 62 degrees. I turned the a/c on just to test for cooler air, it only blows hot air regardless of set temperature. What do you think is the problem?
Sounds like something is wrong with the climate control cable that attaches to the heater core. You can manually reach under the dash to the heatercore and turn down the heat there.
also noticed this morning that both cooling fans come on with the a/c on but only for about 1-2 mins before they stopped. i think they are supposed to be on all the time with a/c running, no?
crxtreme89h
Dec 12, 2005 03:17 PM
bigslimdog
16
Jan 27, 2004 02:51 PM
technine
Sep 16, 2002 01:28 PM
