Suspension & Brakes Theory, alignment, spring rates....
Camber Kits???
Old Nov 2, 2006 | 11:39 AM
slow_ls's Avatar
Default Camber Kits???
I know camber kits and whether you need them or not is discussed on almost a daily basis it's just I would like to get an answer for my particular set up, and not wanting to spend the money for them. I have a 2000 ls integra and I'm going to be ordering the complete omni power coilovers tonight. I would like to just eliminate wheel gap front and back which is basically 2 inches. So do I need a camber kit, beacause I want to order it when I get the coilovers. And if so front, back or both. Thanks
Old Nov 2, 2006 | 12:45 PM
TunerN00b's Avatar
Default Re: Camber Kits??? (slow_ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_ls &raquo;</TD></TR><TR><TD CLASS="quote">I know camber kits and whether you need them or not is discussed on almost a daily basis it's just I would like to get an answer for my particular set up, and not wanting to spend the money for them. I have a 2000 ls integra and I'm going to be ordering the complete omni power coilovers tonight. I would like to just eliminate wheel gap front and back which is basically 2 inches. So do I need a camber kit, beacause I want to order it when I get the coilovers. And if so front, back or both. Thanks </TD></TR></TABLE>
I drove that low without them for a while with my 00 GSR. When I decided I wanted more negative camber, then I got a camber kit. Thats what I would recommend to you as well, lower the car to the height you want, then go get an alignment ASAP, to get your toe correctly set to avoid excessive tire wear. You'll probably be around -2* or so in the front after the lowering, which is perfectly fine for daily use, and less in the rear (I was at -1.6*).
In addition to replacing the UCA with a new point of potential failure (just bolt tension holding a sliding plate in place), you'll also lose some available suspension travel from the taller balljoint, which is the last thing you want to lose with a car dumped the the point of flushed tires.
Old Nov 2, 2006 | 01:01 PM
8520's Avatar
Default Re: Camber Kits??? (TunerN00b)
None necessary. I have -2.8 and -2.7 on my car and my tires are perfectly fine.
Old Nov 2, 2006 | 01:04 PM
Tyson's Avatar
Default Re: Camber Kits??? (misanthropist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misanthropist &raquo;</TD></TR><TR><TD CLASS="quote">None necessary. I have -2.8 and -2.7 on my car and my tires are perfectly fine.</TD></TR></TABLE>
and did you get an alignment?
Old Nov 2, 2006 | 01:37 PM
8520's Avatar
Default Re: Camber Kits??? (Tyson)
Absolutely. Only thing that spares my tires.
Old Nov 2, 2006 | 01:40 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misanthropist &raquo;</TD></TR><TR><TD CLASS="quote">Absolutely. Only thing that spares my tires. </TD></TR></TABLE>
Old Nov 2, 2006 | 02:28 PM
SolLesHonda's Avatar
As long as you get a toe alignment, you'll be fine.
My car is lowered a lot, and it is been fine so far on my tires.
Old Nov 2, 2006 | 02:52 PM
slow_ls's Avatar
So don't waste my money on a camber kit. Then why do they even sell these things, just for people who want to fine tune for the track I guess.
Old Nov 2, 2006 | 03:01 PM
Tyson's Avatar
Default Re: (slow_ls)
mostly because there are still ppl who say you NEED camber kits to save your tires and dont know any better because theyve been spoonfed that line for years, and continue to regurgitate this misinformation.
actually, its really just hondas that dont need camber kits. most other cars that dont have double wishbone suspension have such horrible camber control it does make a difference. but whats always important is toe needs to be aligned after lowering and is often neglected.
ITR_1211
Honda S2000
Apr 14, 2005 01:15 PM
tekkynikality
Feb 10, 2004 06:52 PM
austrian type-R
Jul 8, 2003 10:46 AM
handa
Jun 14, 2003 10:04 PM
slvrcivic97
Oct 17, 2002 05:57 PM
