b16a burning oil
Old Nov 2, 2006 | 03:17 AM
trini_jdm's Avatar
Default b16a burning oil
Hi guys,
I purchased an SIR(b16a) 3 months ago ,In the first week I changed the oil (mobil1)and after a month I noticed that the dip stick is reading quater,I keep topping it up(approximately 1 1/2 quart excess ) until last month I change the oil and filter and notice the same issue happening .
I need to know what is probably causing this ?
the is car driven hard occasionally!
Regards
Old Nov 2, 2006 | 03:21 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: b16a burning oil (trini_jdm)
Could be anything.
Oil leak.
Valve seals.
Blow-by (bad rings)
I'd start by doing a compression and leak down test.
Old Nov 2, 2006 | 03:41 AM
trini_jdm's Avatar
there's definately no oil leaks.
Thanks JDM-Ej, I'll look to having a test done.
I need to have an idea of exactly whats parts in particlar thats has to change.
Old Nov 2, 2006 | 11:27 AM
hondadriver's Avatar
After about 3 months of using royal purple in my JDM 2nd gen b16a i started to burn oil about 1 quart every 1000 miles. Did a compression test and the numbers came out fine. So I was gonna have my valve seals replaced and a month before doing it I was low on oil (didn't know) took a turn on a thruway on ramp at about 50, oil light came on for a second, then the next day after warming up, I hear CLUNK, CLUNK, at about 3k rpm. SPUN a rod bearing. SO instead of rebuilding it I just got another fully assembled block. But when I removed my head the intake valves in the first cylinder had oil residue around them. So my guess would be your seals are done.
Old Nov 4, 2006 | 11:48 PM
V.W.O.A.'s Avatar
more then likely you have a car that either has bad valve guides or is experiencing "blow-by" which is where the piston rings are not sealing properly thus allowing oil to mix into the combustion chamber/combustion to enter your oil supply which also burns oil. Have a friend follow you out driving, make sure to take the car to redline a couple times and see if they notice the car exhausting smoke. If it is, definetely one of these two things. Otherwise check to see if there are any leaks maybe?
jonyi27
Apr 21, 2014 11:55 AM
Rok_Stok
27
Oct 24, 2009 08:22 PM
saemoonyang
Jul 15, 2009 08:38 PM
bigslimdog
42
Mar 27, 2004 03:02 PM
Accel Junky
Apr 28, 2003 02:18 PM
