Jerky steering wheel at high speeds
Old Nov 2, 2006 | 01:19 AM
DC2_005200's Avatar
Default Jerky steering wheel at high speeds
Well heres the background....got a 94 GSR running an LS/Vtec. Gots polyurethane motor mounts but is missing the torque mounts that goes on the tranny and the A/C mount, due to me swapping out the engine last month. Car is lower with tokico blues and ebiach springs. No adjustable camber kit. Also car has a Momo steering wheel.
Problem: Even before I changed the motor the car would start viberating at high speeds, say about 50 Mph+, and you really notice it when i am punching it. At first i thought it could be the motor mounts, but then sometimes when I am driving, you know how the have those recently patches of asphalt like they did some work in the road, it would want to follow that. So I have an idea that I diffently have to fix this camber due to me having some modeate camber wear on my tires. But could it be anything else?
I was thinking about bending my knuckles to fix that camber problem seeing that some of the guys camber kits doesnt fully adjust his height.....
So wondering if anyone has ever had this problem before or you might know whats up, let me know so i can fix my baby. Thanks
Old Nov 2, 2006 | 04:23 AM
Tizight's Avatar
Bent rim.
I had this problem with my other car.
Old Nov 2, 2006 | 06:02 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Jerky steering wheel at high speeds (DC2_005200)
Whens the last time you've had the tires balanced or, had it aligned?
Old Nov 2, 2006 | 09:56 AM
DC2_005200's Avatar
Default Re: Jerky steering wheel at high speeds (CleanLikeJdm)
but it happens with any rim i use....my oem fat fives some rota mf-8s. i think we could rule out the rims
Old Nov 2, 2006 | 09:58 AM
DC2_005200's Avatar
well tires are always balanced....but alignement might have been for a while. you think that could be the problem right there
Old Nov 2, 2006 | 12:24 PM
91tegraRS's Avatar
i had the same problem and it turned out to be the axle ........cheap *** auto zone axles ......good thing they are lifetime guarantee cause i had to replace it three times to fix the vibration.i guess it was just a cheap rebuild
Old Nov 2, 2006 | 12:29 PM
Zion-I's Avatar
Default Re: Jerky steering wheel at high speeds (91tegraRS)
check your CV boots, I had that same problem and found that my CV boots were worn
Old Nov 2, 2006 | 12:40 PM
Sweetsystem's Avatar
Yes. Those Cheap Reman Axles do tend to lose there balance at high speeds 90+.
Also I think you should check your Tie Rod Ends, and looseness in the Wheel Hub Bearing Assembly.
Next time your driving at around 50mph or so, shimmy the steering wheel left and right and try to Gage the looseness of the steering wheel. I would say about 1/2 inch is Maximum allowable end play. If you have more than an inch you should really take it in and have it thoroughly checked out by a professional for your own safety.
Let us know what you find out.
Modified by Sweetsystem at 4:03 PM 11/3/2006
Old Nov 2, 2006 | 12:53 PM
95 integra's Avatar
Default Re: Jerky steering wheel at high speeds (Sweetsystem)
Could be an axle, alignment, wheel bearing or bad tires (my dad had a set of brand new goodyears w/ seperated belts). Also doing things like "bending the knuckles" can have adverse effects on the car....not to mention you arent running torque mounts. Keep doing things incorrectly and you'll keep getting poor results.
Old Nov 2, 2006 | 04:34 PM
DC2_005200's Avatar
Default Re: Jerky steering wheel at high speeds (DC2_Junkie)
well i replace the axles a while back, and double check them. they are all fine
Old Nov 2, 2006 | 04:39 PM
DC2_005200's Avatar
Default Re: Jerky steering wheel at high speeds (95 integra)
yeah thats why I am here try to find postive results now, not a list of everything I just listed. plus has anyone used bent knuckles....few of the DC2s have done them down here and had no problems, but does not dismiss that the facts they are problems. Can you elaborate on the adverse effect of the car. Not try to sound hosile, but dont want to dismiss possible soultions either.
Old Nov 2, 2006 | 04:57 PM
harrykong's Avatar
alignment, wheel bearing or bad tires. cheack tire pressure to if there even this will help alot.
Old Nov 2, 2006 | 06:25 PM
DC2_005200's Avatar
Default Re: Jerky steering wheel at high speeds (harrykong)
well for sure i am going to get a new alignment, but i know i got to get the camber kits. But tire tread and pressure is fine. i know that the wheel bearing goes bad when it starts making noise....but how else can you check without taking it out? I really hate taking it out
Old Nov 2, 2006 | 06:36 PM
95 integra's Avatar
Jack the car up and wiggle the wheel/tire. If it wiggles round and round like the wheel is about to fall off, then the wheel bearing is bad.
Old Nov 2, 2006 | 08:08 PM
27whp_teg's Avatar
when i hit around 55-65 i had the same problem with my old car....i replaced tie rods and the problem went away...i would honestly check those.
Old Nov 2, 2006 | 10:26 PM
trickedvtec's Avatar
i have been having the same problems since i replaced my axles i never thought it would be that .. also noticed it alot when i changed my suspension. got a alinement and still doing to the same thing .. so from what im reading here .. i should get my front axles i got from auto replaced?
Old Nov 3, 2006 | 07:16 AM
Wheel bearings do make a Grinding noise or light squeal when going bad. BUT I have also seen from experience the hub getting loose without any noise or indication of a problem at all. I had a CRX with a loose front right hub, with all other components prevented from moving I could shift the wheel from the edge of the tire a good 1/2 inch back and forth (like I was steering the car). Replaced the whole knuckle because I didn't want to mess with that safety issue! I think the Races the bearings roll on can sometimes get worn down from abrasion and/or heat and possibly hard impacts if your suspension is too stiff.
I am really intrested in the final outcome of your problem, please post your trouble shooting methods and how you narrowed the problems down when you figure it out.
Old Dec 1, 2006 | 09:47 PM
tofu man's Avatar
Bump for some closure! I'm having the same issue! What happened?
Old Dec 1, 2006 | 11:06 PM
dvp's Avatar
dvp
Default Re: Jerky steering wheel at high speeds (cw.tech)
Worn suspension bushings will also do the same.
Old Dec 1, 2006 | 11:39 PM
tofu man's Avatar
Default Re: Jerky steering wheel at high speeds (dvp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvp &raquo;</TD></TR><TR><TD CLASS="quote">Worn suspension bushings will also do the same.</TD></TR></TABLE>
<U>ALL</U> suspension has been replaced, and wheels and tires.
Old Dec 2, 2006 | 06:53 AM
aaronISthrowed's Avatar
Could be a weak motor mount(s).
Old Dec 2, 2006 | 10:06 AM
tofu man's Avatar
Default Re: Jerky steering wheel at high speeds (aaronISthrowed)
those have been replace with poly inserts. all except the back ones, because one of the bolts is stripped.
lud_08
Suspension & Brakes
Oct 12, 2010 04:44 AM
gsr dood
Dec 28, 2005 11:16 AM
vteg
May 22, 2002 06:17 PM
TexTeg
Apr 7, 2002 11:07 AM
