Rolling Fenders
What exactly is rolling fenders? I know it has something to do with giving more room for tires on a lower car, my friend rolled his fenders on his s2k, but i failed to see a cosmetic difference. What exactly does it change, and how is it done?
Guest
Posts: n/a
it basically rolls the inner lip of the fender in so tires won't rub you can't really tell if it's done unless you look up under the fender
http://www.tirerack.com/access...p.jsp
300 bucks, wow.
I use a baseball bat and wedge it against the tire, while pulling up and rolling the outer edge, carefully.
$17, 15 minutes of time and a little massaging/TLC..... priceless.
JMHO
Donnie
JMHO
Donnie
About 4 of us split the cost of renting this so it worked out to like 20 bucks a person. was very easy to use and much easier then the baseball bat method
http://www.rollyourfender.com/
Modified by H4crxGuy at 9:30 AM 11/3/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Akadem1kONE »</TD></TR><TR><TD CLASS="quote">It's also done mostly on RWD vehicles, so they get the "flush" look for their low offset and wide rims.</TD></TR></TABLE>
no sure why you would say that. when my integra was a street car I had to roll the renders to clear my rim/tire combo.. But I had a body shop do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianZ »</TD></TR><TR><TD CLASS="quote">no sure why you would say that. when my integra was a street car I had to roll the renders to clear my rim/tire combo.. But I had a body shop do it. </TD></TR></TABLE>
I didn't mean it was just for RWD cars. I just said that it's usually done with the RWD crowd because of the nature of how alot of them want their rims to sit flush with the fender.
Awluiz
Feb 11, 2013 10:40 AM
msinsky14
Apr 16, 2006 02:12 PM
quiambao1180
12
Oct 16, 2004 08:08 PM
