clutch and transmission between a series
Ok the flywheel is only attached to the motor...so as long as the clutchs's pressure plate bolts up to it your good..the splines one the disk are what determins weither or not the tranny bolts up to it..and as far as i know allll the 92-00 D series trannies are the same (as far as fitment) only the cable trannys had 2 diffrent types. The only way to find out for sure is to pull the clutch disk out and see if it will slide onto the imput shaft on the tranny...(major pain in the ***)
