battery problem
hey i have my 1990 ef hatch. i have a problem with the battery light it is on all the time. i have change battery with a new one but still same problem. does any one know what it could be?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by htowncruiser »</TD></TR><TR><TD CLASS="quote">what if the alternator is new as well? i just change it today as well cuz i had warranty on it. but still the same. </TD></TR></TABLE>
check the wiring from the alternator to the + terminal of the battery. Make sure there is a secure connection, and there is no corrosion. If you do not have the proper equipment to check the conditon of the charging system, then I would recommend taking your vehicle to someone that does. There is only so much you could do or check, without a multimeter, or midtronics tester.
Good luck
Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllmansDB8* »</TD></TR><TR><TD CLASS="quote">
check the wiring from the alternator to the + terminal of the battery. Make sure there is a secure connection, and there is no corrosion. </TD></TR></TABLE>
i agree.. sounds like the return from the alt to the battery is not secure,. or corroded to where power does not flow.. i had a ground cable like that on a ford pickup.. was corroded down the whole cable.. replaced it and treuck would start.. neat concept huh
hondastrtracr
16
Jan 27, 2008 09:16 PM
mycivicswaylow53
21
Nov 8, 2007 08:50 PM
