A question about VAFC
Old Nov 1, 2006 | 06:07 PM
mtpktz.'s Avatar
Default A question about VAFC
My car is a 99 GSR and is currently running on VAFC. I am running a bit rich and am not able to pass emissions. Emissions allowed is 1.2000 I got 1.6xxx today.
Anyways, my VAFC screen is broken, and I would like to buy a new one. I am curious, is there a way to transfer data from one VAFC to another? (I would like to lean out my car but am not able to do so being that I can not see the VAFC screen.)
Thanks for any and all help.
Old Nov 1, 2006 | 07:39 PM
TunerN00b's Avatar
Default Re: A question about VAFC (mtpktz.)
Why don't you just remove it, and run the car on the factory tune to pass smog?
Old Nov 1, 2006 | 07:46 PM
mtpktz.'s Avatar
Default Re: A question about VAFC (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">Why don't you just remove it, and run the car on the factory tune to pass smog?</TD></TR></TABLE>
That's what I plan to do, I'm not going to run the VAFC anymore.
I was told all I have to do is unplug the VAFC from the ECU harness. True?
The car is not stock, it has LS crank/rods and ITR pistons, DC 4-2-1 header ITR stock airbox and ITR catback. Eventually I'll get a tune.
Old Nov 1, 2006 | 07:58 PM
no2unenolife's Avatar
you can't just unplug the vafc from the harness.
the map (pressure) wire needs to be reconnected
Old Nov 1, 2006 | 08:04 PM
mtpktz.'s Avatar
Default Re: (no2unenolife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2unenolife &raquo;</TD></TR><TR><TD CLASS="quote">you can't just unplug the vafc from the harness.
the map (pressure) wire needs to be reconnected</TD></TR></TABLE>
is that all that needs to be plugged back in? just the MAP sensor?
Old Dec 25, 2006 | 11:26 AM
davidc's Avatar
Default Re: (mtpktz.)
Yes, but call Apexi for more info.
Old Dec 25, 2006 | 12:43 PM
martyball619's Avatar
Default Re: (davidc)
i dont think ull pass smog with ITR pistons.. but correct me if im wrong
ci_v_ic
11
Aug 5, 2006 12:40 PM
B00ST2nR
May 10, 2004 10:09 PM
EK_BackHatch
12
Mar 4, 2004 02:05 AM
BseriesHatch
Dec 29, 2003 12:26 PM
