b16 swap alternator clearnace issues
Old Nov 1, 2006 | 05:50 PM
Chief Wenceslaw's Avatar
Default b16 swap alternator clearnace issues
Swapping a b16a into an 88 hf. I tried beating the hell out of the side of the engine bay to get it to fit, no dice. Then I tried cutting a hole in the side, but it still won't clear on the bottom, and I can't cut any lower because that's where the rear crossmember is bolted into. I do have an AEM alternator pulley, but it didn't look like it would be too much of a problem. Any ideas?
Old Nov 1, 2006 | 06:47 PM
Redline130's Avatar
Default Re: b16 swap alternator clearnace issues (Chief Wenceslaw)
What mount kit are you using?
Old Nov 1, 2006 | 06:53 PM
hybridmiklo's Avatar
Default Re: b16 swap alternator clearnace issues (Redline130)
Oh, thought you were replacing alternator.
Old Nov 1, 2006 | 06:57 PM
Default Re: b16 swap alternator clearnace issues (hybridmiklo)
cheapy ebay one . I suppose it's possible that the driver's side mount is too short, pulling the motor closer to that side. I pulled the motor out of an 89 Si, the driver's side mount was bad so I bought an ebay mount kit. but I didn't discern any noticeable difference from the old mount when I replaced it, but I guess there could be one.
Old Nov 1, 2006 | 08:45 PM
jdm_ef9_b16's Avatar
get you a BIGGER hammer. me and friend have done it plenty of times. get a mini sledge and beat the **** out of it.
Old Nov 2, 2006 | 01:25 AM
Bunger's Avatar
Default Re: (jdm_ef9_b16)
Or run a smaller belt. I run a belt so small that you can barely get it on, but when used with a HASport mount kit, I didn't even have to touch the car with a sledge. I doubt this will be possible with an AEM alt pulley, they are a decent amount bigger.
Old Nov 3, 2006 | 11:01 PM
Default Re: (Bunger)
I could run a smaller belt, but that wouldn't help clear the pulley itself. Also, I already cut a hole in the sidewall, and I don't know if I can beat it anymore beacuse I'm to the pint where the rear crossmember bolts to the frame.
daigo
Jan 3, 2011 05:42 AM
tcs8ter
Texas -OK -LA (Sales)
11
Dec 13, 2007 06:54 AM
TylerC161
May 1, 2007 01:11 AM
onnoff7
Feb 2, 2006 08:37 AM
KINGVIPER12
Mar 21, 2005 11:06 AM
