the results are in !!!!!!!!!!!!!
Old Nov 1, 2006 | 05:23 PM
ALL IMPORT's Avatar
Default the results are in !!!!!!!!!!!!!
well after months of messing with the damn twin fire JUNK, the msd6a came throught tonight. the end result was 512whp 335tq 22psi at only 8500rpm.
i am just amazed 3 months to get this right & it took a cheaper ignition.
Old Nov 1, 2006 | 05:35 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: the results are in !!!!!!!!!!!!! (ALL IMPORT)
uhhh ok...lol
Old Nov 1, 2006 | 05:36 PM
Jared's Avatar
ive made that power with stock ignition setup and colder plugs. what is the problem?
Old Nov 1, 2006 | 05:38 PM
Gravy's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">ive made that power with stock ignition setup and colder plugs. what is the problem?</TD></TR></TABLE>
so did M.A.R.C.'s car...
Old Nov 1, 2006 | 05:46 PM
ALL IMPORT's Avatar
Default Re: (Gravy)
hey bump u peepz, i forgot u are the big dogs D*cks always trying to kill someone high, if u knew the story behing this u would see why its so special
Old Nov 1, 2006 | 05:58 PM
Gravy's Avatar
Default Re: (ALL IMPORT)
that dyno sheet looks like a kid was using crayons! haha
Old Nov 1, 2006 | 06:03 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (Gravy)
HaTerZ!
Old Nov 1, 2006 | 06:08 PM
Turbocivic94's Avatar
Default Re: (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">HaTerZ!</TD></TR></TABLE>
lol
Old Nov 1, 2006 | 08:34 PM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT &raquo;</TD></TR><TR><TD CLASS="quote">well after months of messing with the damn twin fire JUNK, the msd6a came throught tonight. the end result was 512whp 335tq 22psi at only 8500rpm.
i am just amazed 3 months to get this right & it took a cheaper ignition. </TD></TR></TABLE>
i woulda tried stock ignition before i tried an msd. i've had no bad experience with msd but if the car was breaking up or giving problems on an aftermarket i'd have tried stock first. either way congrats on the numbers. it feels good to finally "get it right"
Old Nov 2, 2006 | 02:55 AM
ALL IMPORT's Avatar
Default Re: the results are in !!!!!!!!!!!!! (M.A.R.C.)
well i was making 390 on stock ignition with a ss coil, but with the 255 pump & 1000cc inj i couldent go past that. so know we have climed over the hill, we a actually made 550whp but we are loosing traction on the dyno. wel owerd the tire down to 12 psi & went from 408 to 512, & it still broke loose so we figure their was 550 thier still. now its time to go for 600 keep going till i hit 700+
Old Nov 2, 2006 | 06:49 AM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT &raquo;</TD></TR><TR><TD CLASS="quote">well i was making 390 on stock ignition with a ss coil, but with the 255 pump & 1000cc inj i couldent go past that. so know we have climed over the hill, we a actually made 550whp but we are loosing traction on the dyno. wel owerd the tire down to 12 psi & went from 408 to 512, & it still broke loose so we figure their was 550 thier still. now its time to go for 600 keep going till i hit 700+</TD></TR></TABLE>
255 pump and 1000cc injectors not enough for 390?? what the hell?
dood i'm on a 255 and 880cc injectors and i'm up over 500 now and the duty cycle is fine.
or did you mean 590?
Old Nov 2, 2006 | 08:44 AM
93supercoupe's Avatar
was this on a d eries or some ****, damn.
Old Nov 2, 2006 | 09:46 AM
JDMisGOOD's Avatar
Default Re: the results are in !!!!!!!!!!!!! (93supercoupe)
Congrats on getting your problems resolved!
Old Nov 2, 2006 | 12:04 PM
WestSideDave's Avatar
Default Re: the results are in !!!!!!!!!!!!! (JDMisGOOD)
Old Nov 2, 2006 | 01:09 PM
nonvtecallmotor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">was this on a d eries or some ****, damn.</TD></TR></TABLE>
Old Nov 2, 2006 | 01:25 PM
2point2's Avatar
Default Re: the results are in !!!!!!!!!!!!! (nonvtecallmotor)
I think it's really cute how they have instructions and parts to wire in a backup. Hopefully the switch wont **** up.
Old Nov 2, 2006 | 02:51 PM
ALL IMPORT's Avatar
u need to read before u typ. i said nothing about injectors or pump failing.
IGNITION FAILURE!!!!!!
u can have all the fuel & big injectors but if iu aint burning it u aint doin sh*t.
some people on here need to go back to school & study reading comprehention.
aslo it is a b series
Old Nov 2, 2006 | 04:32 PM
tony1's Avatar
Default Re: the results are in !!!!!!!!!!!!! (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
I think it's really cute how they have instructions and parts to wire in a backup. Hopefully the switch wont **** up.</TD></TR></TABLE>
LOL
Old Nov 2, 2006 | 04:45 PM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT &raquo;</TD></TR><TR><TD CLASS="quote">u need to read before u typ. i said nothing about injectors or pump failing.
aslo it is a b series</TD></TR></TABLE>
I did read...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT &raquo;</TD></TR><TR><TD CLASS="quote">well i was making 390 on stock ignition with a ss coil, but with the 255 pump & 1000cc inj i couldent go past that.</TD></TR></TABLE>
why would you not be able to go past 390 on a stock ignition? you never referred to your stock ignition failing in that post... you only mentioned that the twin power wasn't working right. we're all saying people have made well over that power on stock ignition. now if your stock ignition was fucked up that's a diff story but you never mentioned it. calm down. don't get so defensive.
Old Nov 2, 2006 | 05:24 PM
ALL IMPORT's Avatar
thats how far the twin fires were letting me go. dont know whyy either.
we never tried going past 400 till we resolved the ignition issue, no point in pushing it.
Old Nov 2, 2006 | 07:17 PM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT &raquo;</TD></TR><TR><TD CLASS="quote">thats how far the twin fires were letting me go. dont know whyy either.
we never tried going past 400 till we resolved the ignition issue, no point in pushing it.</TD></TR></TABLE>
now i'm confused. earlier you said you didn't go past 390 on stock ignition... now ur sayin on the twin fire?
Old Nov 3, 2006 | 01:03 AM
IT'S ME DAVID's Avatar
NooB
Default Re: (Gravy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gravy &raquo;</TD></TR><TR><TD CLASS="quote">that dyno sheet looks like a kid was using crayons! haha</TD></TR></TABLE>
Old Nov 3, 2006 | 02:46 AM
ALL IMPORT's Avatar
tuned to 390 stoped, got the twine fire put it in had problems with 2 of them, took it out never tried going higher on the stock setup , then got the msd
Old Nov 3, 2006 | 03:53 AM
11SEC CIV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL IMPORT &raquo;</TD></TR><TR><TD CLASS="quote"><U>some people on here need to go back to school</U> & study reading comprehention.
LOL
Dartanian
Mar 26, 2006 06:48 PM
Sketch_hs
May 10, 2005 06:54 PM
clemsoncb7
Jun 30, 2004 03:38 PM
92HB_HB
Oct 30, 2003 01:13 PM
steroidguy
Oct 7, 2003 06:59 PM
