accord with vtec problem
Old Nov 1, 2006 | 05:02 PM
metal craft's Avatar
Default accord with vtec problem
i just put my buddies 95 prelude motor in his car from japan and the motor runs perfect, but i cant get the vtec to come on, i tried with a vtec controller and still didnt work, i hooked it up manualy the selonoid comes on but the vtec will not work no matter what i did, it doesnt cut back or change the sound of motor when i turn it on, i took the selonoid apart and cleaned it still didnt work any advice would help.
Old Nov 1, 2006 | 05:28 PM
Ross 2.0's Avatar
In a Junkyard near you.
Have you checked the oil pressure?
Old Nov 1, 2006 | 07:25 PM
ex95cord's Avatar
Def check the oil pressure, but I would think that because they just put it in the oil level and pressure would be fine...
Old Nov 1, 2006 | 08:19 PM
hondadude's Avatar
Default Re: accord with vtec problem (metal craft)
Just what exactly do you expect to happen when you 'manually' turn on the Vtec solenoid? All that is doing is locking the intake rockers together to change the cam profile.
Click up this link to educate yourself
The only way you would know is to watch with the valve cover off.
Nitr0EngiEx
Nov 12, 2012 01:32 PM
thunderboy
Jan 6, 2011 10:13 AM
speedunlimited
Sep 16, 2004 08:08 AM
CA6VTEC
Nov 2, 2003 03:17 AM
r7
Jun 28, 2002 02:24 PM
