Koni Yellows?
Old Nov 1, 2006 | 12:58 PM
Ill Mitch's Avatar
Default Koni Yellows?
i did search, been reading OLD posts for last 45min.
anyone using them on the ITR now? i have TEIN springs and thats it. what are the suggestions you guys have?
Thanks
Old Nov 1, 2006 | 12:59 PM
BlueR's Avatar
Default Re: Koni Yellows? (Ill Mitch)
ITR specific Bilstein sports
Old Nov 2, 2006 | 04:30 AM
Larkin W.'s Avatar
Default Re: Koni Yellows? (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">ITR specific Bilstein sports </TD></TR></TABLE>
Yup. Bilstein SP's are where its at. I love mine
Old Nov 2, 2006 | 05:06 AM
jetydosa's Avatar
25 Year Member
Default Re: Koni Yellows? (Larkin W.)
Koni yellows are great shocks. A Koni yellow +GC setup is a great ticket.
If you want to run stiffer springs than ~500lbs you will want to have them revalved (or get already race-valved Konis from Redshift Motorsports).
If your car is a DD and you dont care that much about being competitive in autox you might want to run Konis w/stock R shocks or if you want to lower the car go ahead and get the Ground Controls and just choose moderate spring rates.
Old Nov 2, 2006 | 05:24 AM
bender's Avatar
Default Re: Koni Yellows? (jetydosa)
Acting as jasmadosa's editor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa &raquo;</TD></TR><TR><TD CLASS="quote">Koni yellows are great shocks. A Koni yellow +GC setup is a great ticket.
If your car is a DD and you dont care that much about being competitive in autox in STX, but want to be competitive in D Stock you might want to run Konis w/stock R springs or if you want to lower the car go ahead and get the Ground Controls and just choose moderate spring rates.</TD></TR></TABLE>
Old Nov 2, 2006 | 07:00 AM
jetydosa's Avatar
25 Year Member
Default Re: Koni Yellows? (bender)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bender &raquo;</TD></TR><TR><TD CLASS="quote">Acting as jasmadosa's editor
Read his other posts, tool, he is already in STX
Old Nov 2, 2006 | 07:15 AM
bender's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetydosa &raquo;</TD></TR><TR><TD CLASS="quote">Read his other posts, tool, he is already in STX </TD></TR></TABLE>
Which is why I clarified 'uncompetitive in autox' to 'uncompetitive in STX, comptetitive in DS'.
-bender, who is a tool; kinda like jumper cables. Zing!!!
Old Nov 2, 2006 | 07:20 AM
jetydosa's Avatar
25 Year Member
:golfclap:
Old Nov 2, 2006 | 07:35 AM
Todd00's Avatar
I said I don't want a title!
Suspension is not the main problem in STX. The problem is that no one makes a shorter and fatter street tire that will fit properly on the ITR.
A 235/40/16 in an Azenis is what we need. The AWD cars just have a much better tire selection.
Old Nov 2, 2006 | 07:44 AM
Ill Mitch's Avatar
im still trying to figure that one out!
AWD / Turbo = NA / FWD?????
Old Nov 2, 2006 | 07:58 AM
jetydosa's Avatar
25 Year Member
Default Re: (Ill Mitch)
Well in the WRXes defense, it is significantly heavier (400lbs+) and has an inferior suspension design (vs the ITR). However they can make mad power with bolt-ons (they gain much more out of I/H/E than we do) , and like Todd said the traction advatage of 245s + AWD = rough life for FWD.
Old Nov 2, 2006 | 08:24 AM
Todd00's Avatar
Default Re: (jetydosa)
In a ST class, don't discount the benefit of street tires and AWD. Also, the WRX only has a 99.x" wheelbase, compared to the ITR's that is 101.x".
The WRX also puts down 230+ HP @ the wheels and a boatload of midrange torque in STX trim.
The strut suspension design can be somewhat fixed with springrates and camber/caster adjustment.
With all of this, the extra weight it carries around is offset by the above.
The ITR still does some things better than the WRX does, but you're gonna need a course that has a lot of these elements in it, such as high-speed slaloms and offsets. Low speed corners to straights and sweepers favor the WRX.
Old Nov 2, 2006 | 07:53 PM
christuffeR's Avatar
i have koni yellows and gc setup and i like it. but then again i've never had any other set up to compare it to. when i first bought my R the previous owner had kyb shocks and ls springs and probably kept the R stock shocks n springs... :
Old Nov 2, 2006 | 11:56 PM
APCforthewin's Avatar
Default Re: Koni Yellows? (christuffeR)
Koni yel's = pure sex....great shocks
ds0440
Suspension & Brakes
Jun 14, 2007 11:32 PM
japhonda
Suspension & Brakes
11
Aug 26, 2005 10:43 AM
lowlight
Suspension & Brakes
Jul 8, 2005 03:25 PM
oe4u
Suspension & Brakes
Apr 23, 2005 08:49 PM
bruinteg
Mar 4, 2004 07:51 PM
